[pgrouting-users] Cannot Create a Network Nodes network nodes
Piyush Shah piyush_shah at ymail.com
Wed Feb 16 02:46:59 EST 2011
Thank You for your Reply,
But I know What is the problem when i had see the assign_vertex_id function in that there is one for loop for taking srid value from input geom_table at that point only Error is occurring so i had statically assign the srid := 4326 (my Spatial table projection) the function works perfectly.
But you can help to understand what is the problem in that "for loop"
I am sending the function body to you in that i had highlighted the code where error is occurring (See Below) :-
CREATE OR REPLACE FUNCTION assign_vertex_id(geom_table character varying, tolerance double precision, geo_cname character varying, gid_cname character varying)
  RETURNS character varying AS
$BODY$
DECLARE
    _r record;
    source_id int;
    target_id int;
    srid integer;
BEGIN
    BEGIN
    DROP TABLE vertices_tmp;
    EXCEPTION
    WHEN UNDEFINED_TABLE THEN
    END;
    EXECUTE 'CREATE TABLE vertices_tmp (id serial)';
   -- FOR _r IN EXECUTE 'SELECT srid(geometry_columns) from '''|| quote_ident(geom_table)||''';' LOOP
--    srid := _r.srid;
    --END LOOP;
    srid := 4326;
    EXECUTE 'SELECT addGeometryColumn(''vertices_tmp'', ''the_geom'', '||srid||', ''POINT'', 2)';
    CREATE INDEX vertices_tmp_idx ON vertices_tmp USING GIST (the_geom);
    FOR _r IN EXECUTE 'SELECT ' || quote_ident(gid_cname) || ' AS id,'
        || ' StartPoint('|| quote_ident(geo_cname) ||') AS source,'
            || ' EndPoint('|| quote_ident(geo_cname) ||') as target'
        || ' FROM ' || quote_ident(geom_table)
    LOOP
        source_id := point_to_id(setsrid(_r.source, srid), tolerance);
    target_id := point_to_id(setsrid(_r.target, srid), tolerance);
    EXECUTE 'update ' || quote_ident(geom_table) ||
        ' SET source = ' || source_id ||
        ', target = ' || target_id ||
        ' WHERE ' || quote_ident(gid_cname) || ' =  ' || _r.id;
    END LOOP;
    RETURN 'OK';
END;
$BODY$
  LANGUAGE 'plpgsql' VOLATILE STRICT
  COST 100;
ALTER FUNCTION assign_vertex_id(character varying, double precision, character varying, c
PIYUSH M SHAH
--- On Tue, 15/2/11, Daniel Kastl <daniel at georepublic.de> wrote:
Subject: Re: [pgrouting-users] Cannot Create a Network Nodes network nodes
To: "pgRouting users mailing list" <pgrouting-users at lists.osgeo.org>
Date: Tuesday, 15 February, 2011, 3:06 PM
How does your network table look like?Did you make sure that column names match and also the data types?
Daniel
2011/2/15 Piyush Shah <piyush_shah at ymail.com>
I am new to pgroutine so ineed some help
i am using PostgreSql 8.4 , Postgis 1.5.1, pgRouting-1.03_pg-8.4.2
But when i trying to create network node through assign_vertex_id
"SELECT assign_vertex_id ('India_highway', 0.00001, 'the_geom', 'gid');"
it gives following ERROR
[WARNING  ] SELECT assign_vertex_id ('India_highway', 0.00001, 'the_geom', 'gid')
            NOTICE:  CREATE TABLE will create implicit sequence "vertices_tmp_id_seq" for   serial column "vertices_tmp.id"
            CONTEXT:  SQL
 statement "CREATE TABLE vertices_tmp (id serial)"
            PL/pgSQL function "assign_vertex_id" line 14 at EXECUTE statement
            ERROR:  query string argument of EXECUTE is null
            CONTEXT:  PL/pgSQL function "assign_vertex_id" line 20 at EXECUTE statement
so please help me what is the problem
PIYUSH M SHAH
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
-----Inline Attachment Follows-----
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110216/34d59ebb/attachment.html
More information about the Pgrouting-users mailing list
