[pgrouting-users] about use of navteq data
Emre Koc emrekoch at gmail.com
Thu Jan 13 03:26:41 EST 2011
Hi Lorenzo,
I am also working on navteq data and it seems pretty straightforward to work
with it. Just use assign vertex id 3d and it builds the network correctly.
I will also share my experiences with tsp and directions after I solve how
to use them.
Emre
On Thu, Jan 13, 2011 at 10:18 AM, lorenzo amato <lorenzo.amato at geosdi.org>wrote:
> Hi Charles, Hi list
> Your experience with Navteq data is very interesting.
> Have a nice vacation and give us some more details when you come back!!
> 2011/1/7 Charles Galpin <cgalpin at lhsw.com>
>> Hi Emre
>> I am using navteq data and would be happy to help, but I am about to take
>> a week long vacation tomorrow morning so hopefully you are not in a rush.
>> The short answer is
>> - assign_vertex does a good job of generating the source/target nodes
>> using 0.00001 for me
>> - for speed, I found I needed to limit the amount of data presented to the
>> routing engine. One was is to reduce the data set (ie remove/limit the
>> func_class 4 roads you don't need). The other is I create a rectangle around
>> the start and the end point and some percentage of the distance between the
>> points as the width and limit the data to that. The narrower the rectangle
>> the less data the routing engine uses, but if you have large arching roads
>> you have to increase this (I use about 70%). Either way it helps speed up
>> the routing for me.
>> - For z levels search the archives but both Steven Woodbridge and I posted
>> our versions of a 3d assign_vertex.
>> I'd be happy to answer any specific questions, and look forward to seeing
>> your progress.
>> charles
>> On Jan 7, 2011, at 4:31 AM, Emre Koc wrote:
>> Hello,
>> I am new to pgRouting and trying to figure out how to use it with navteq
>> data. I used pgRouting with osm data and it worked perfect but for navteq
>> data i tried to use ref_in_id and nref_in_id but it turned out that
>> pgRouting found the path very slow when I used these for source and target.
>> How can I calculate a correct topology for pgRouting by taking z levels into
>> consideration ? Shall define geometry as 3D with z levels embedded or is it
>> possible to use 2d multilinestring with additional z level column ?
>> Since I am new to pgRouting these questions are very hard for me to solve,
>> but after I figure out how to use pgRouting I would be more than happy to
>> contribute to project.
>> Thanks in advance,
>> Emre
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Lorenzo Amato
> lorenzotlc at gmail.com
> lorenzo.amato at nsdi.it
> Consiglio Nazionale delle Ricerche
> Istituto di Metodologie per l'Analisi Ambientale - geoSDI
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110113/28a61555/attachment.html
More information about the Pgrouting-users mailing list
