[pgrouting-users] Complilation Errors on Tps and Disjkstra
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jul 30 10:19:38 EDT 2011
Your first error is most likely the issue. The build system can not find
postgres.h which is the postgresql development header file. You need to
install the postgresql development files to build pgRouting. So you
might need to do something like:
sudo yum install postgresql-devel
You need to make sure you all the dependencies installed.
-Steve
On 7/30/2011 6:18 AM, Jules Kouadio wrote:
> Hi everybody
> On  CentOs 5 (french version).
> Why  all this errors after the "make install" for Tps and dijkstra?
> Can someone help me ?
> Thanks !
> ERROR [root at bnetd pgrouting]# make install
> [ 8%] Building C object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o
> Dans le fichier inclus à partir de
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:22:
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.h:25:22: erreur: postgres.h
> : Aucun fichier ou répertoire de ce type Dans le fichier inclus à
> partir de /home/sekedoua/pgrouting/extra/tsp/src/tsp.h:26, à partir de
> /home/sekedoua/pgrouting/core/src/dijkstra.h:25:22: erreur: postgres.h
> : Aucun fichier ou répertoire de ce type In file included from
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.h:26, from
> /home/sekedoua/pgrouting/core/src/dijkstra.h:32: erreur: expected
> specifier-qualifier-list before ‘float8’
> /home/sekedoua/pgrouting/core/src/dijkstra.h:40: erreur: expected
> /home/sekedoua/pgrouting/core/src/dijkstra.h:47: erreur: expected
> declaration specifiers or ‘...’ before ‘bool’
> declaration specifiers or ‘...’ before ‘bool’ In file included from
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.h:31: erreur: expected
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:25:26: erreur:
> executor/spi.h : Aucun fichier ou répertoire de ce type
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:26:21: erreur: funcapi.h
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:27:29: erreur:
> catalog/pg_type.h : Aucun fichier ou répertoire de ce type
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:32:18: erreur: fmgr.h :
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:73: erreur: expected ‘=’,
> ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘tsp’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:98: erreur: expected ‘)’
> before ‘*’ token /home/sekedoua/pgrouting/extra/tsp/src/tsp.c: In
> function ‘finish’: /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:111:
> erreur: ‘SPI_OK_FINISH’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:111: erreur: (Each
> undeclared identifier is reported only once
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:111: erreur: for each
> function it appears in.)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:113: erreur: ‘ERROR’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c: Hors de toute fonction :
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:123: erreur: expected
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:129: erreur: expected ‘)’
> before ‘*’ token /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:152:
> erreur: expected ‘)’ before ‘*’ token
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c: In function ‘solve_tsp’:
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:194: erreur: ‘Portal’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:194: erreur: expected ‘;’
> before ‘SPIportal’ /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:195:
> erreur: ‘bool’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:195: erreur: expected ‘;’
> before ‘moredata’ /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:202:
> erreur: unknown field ‘x’ specified in initializer
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:202: attention : éléments
> en excès dans l'initialisation de la structure
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:202: attention : (near
> initialization for ‘point_columns’)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:202: erreur: unknown
> field ‘y’ specified in initializer
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:228: erreur: ‘ERROR’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:238: erreur:
> ‘SPI_OK_CONNECT’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:244: attention :
> assignment makes pointer from integer without a cast
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:252: erreur: ‘SPIportal’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:252: erreur: ‘true’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:261: erreur: ‘moredata’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:261: erreur: ‘TRUE’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:267: erreur:
> ‘SPI_tuptable’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:271: erreur:
> ‘SPI_processed’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:278: attention :
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:280: attention :
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:291: erreur:
> ‘SPITupleTable’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:291: erreur: ‘tuptable’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:292: erreur: ‘TupleDesc’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:292: erreur: expected ‘;’
> before ‘tupdesc’ /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:298:
> erreur: ‘HeapTuple’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:298: erreur: expected ‘;’
> before ‘tuple’ /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:300:
> erreur: ‘tuple’ undeclared (first use in this function)
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:300: erreur: ‘tupdesc’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:309: erreur: ‘FALSE’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:325: erreur: ‘point_t’
> has no member named ‘x’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:326: erreur: ‘point_t’
> has no member named ‘y’
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:364: erreur:
> ‘ERRCODE_E_R_E_CONTAINING_SQL_NOT_PERMITTED’ undeclared (first use in
> this function) /home/sekedoua/pgrouting/extra/tsp/src/tsp.c: Hors de
> toute fonction : /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:370:
> attention : la définition de données n'a pas de type ni de classe de
> stockage /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:370: attention :
> noms de paramètres (sans type) dans la déclaration de fonction
> /home/sekedoua/pgrouting/extra/tsp/src/tsp.c:372: erreur: expected
> ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘tsp’ make[2]: ***
> [extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o] Erreur 1 make[1]: ***
> [extra/tsp/src/CMakeFiles/routing_tsp.dir/all] Erreur 2 make: ***
> 2011/7/29, Ricardo Bayley<ricardo.bayley at gmail.com>:
>> Hi folks,
>> On the pgRouting website, it says that the latest compiled  windows binaries
>> are for pg8.4.2
>> Is this strictily for 8.4.2 or for all the 8.4.x series ?
>> best regards
>> Ricardo
More information about the Pgrouting-users mailing list
