[pgrouting-users] dijkstra_sp_delta throwing a signal 6 (SIGABRT?)
Richard Marsden winwaed at gmail.com
Wed Mar 2 09:33:36 EST 2011
Update...
Well China did crash. Following from my theory that it is memory leak or
other resource limitation from a large number of calls to pgRouting, I added
code to cleanly close and reopen the connection every 300 points (ie. a max
of 600 pgRouting calls). I also added a local garbage collection call and a
200ms sleep for good measure.
It appears to be working - China is still running (and should do for a week
possibly), but it has run far longer than it did to the first crash or any
of the Brazil crashes.
So there is a resource somewhere that is being "used up" when I have large
numbers of queries on the same connection. When the connection closes, the
resource in question is freed.
The stack is Psycopg -> Postgres -> pgRouting.
I found a reference to someone having a similar problem (no pgRouting, but
lots of SELECTs through Psychopg), and their solution was to do a commit
after every SELECT:
http://stackoverflow.com/questions/4173168/psycopg-postgres-connections-hang-out-randomly
I haven't found any other references to this kind of problem.
Richard
On Tue, Mar 1, 2011 at 10:29 AM, Richard Marsden <winwaed at gmail.com> wrote:
> Thanks for the refs & links - some useful stuff there...
> Oh the wonders of Linux documentation - of course all the forks and
> versions don't help - the references I found to SHMMEM must have been old.
> Thanks for those references. I've upped it to 128MB and shared_memory to a
> conservative 64MB (from 28MB) but the same result.
> (I'm also printing off those two Postgres pages about recommended
> configurations, whilst I type - I'll probably adjust them further.   I have
> the Apress "From Beginner to Expert" PostGres book but of course it is
> cross-platform and is more interested in covering a wide range of topics
> including basic SQL)
> After a few runs now, I'm seeing the abort occurs at different places in
> processing. Assuming that pgrouting's search through the graph is
> deterministic (and I haven't seen anything to say otherwise), this suggests
> the problem is not data (graph) specific.
> I said "threads/processes": Python's implementation of multithreading is
> broken from the multi-core processing perspective - basically there's one
> giant lock on the interpreter!  Luckily the standard libraries include an
> alternative which uses OS processes in a thread-like way. I'm using the
> multiprocessing 'Pool' functions to implement what Google have christened
> "MapReduce" across 1-3 cpus (haven't dared try 4 yet)
> The problem occurs with once process as well as 3 processes, so I don't
> think it is a bulk memory limit - instead it is a single process limit.
> So far I've only seen the problem with Brazil (I'm batch processing
> country-wide mileage charts). This is the biggest chart I've tried
> (Australia was the previous largest and it wasn't that much smaller).
> One thought is that it could be related to the number of calls on a
> connection: perhaps a server-side garbage collector is not getting the
> chance to run?  Or there's a memory leak?
> The maximum number of pgRouting calls per connection is currently 2000.
> Brazil is going to be in the 950-1900ish range (I first try with a small
> delta. If that fails to find a route, I try a larger delta - hence the
> two-fold uncertainty)
> I've now switched to Asia. If I'm right with the above paragraph, it will
> probably fail with India but not China
> (China has lots of cities but a large number are not matched with road
> data, so they are skipped)
> So far it is running okay, but it has only reached Armenia...
> Thanks for the suggestions - they are helping!
> Richard
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110302/fd24eb24/attachment.html
More information about the Pgrouting-users mailing list
