[pgrouting-users] Question regarding shortest_path_shooting_star
Roozbeh Bandari yakhmak2000 at yahoo.com
Mon Mar 14 04:33:54 EDT 2011
Dear Professionals,
It's been a while we are using PostGIS to store our Geometry information in our
Postgress database. We have developed vertex-to-vertex routing ourselves using
iGraph library. Yesterday I read about pgRouting and I am porting our current
application to pgRouting. However, I faces some issues in using shooting start
path finder.
We stored edges and vertices information in tables and for finding a graph route
with turn restriction, we are calling following SQL script:
SELECT  shortest_path_shooting_star(
    'SELECT e.id,
                    e.first as source,
                    e.second as target,
                    ST_Length(e.geom) as cost,
                    st_x(st_pointn(e.geom, 1)) AS x1, st_y(st_pointn(e.geom, 1))
AS y1,
                    st_x(st_pointn(e.geom, 2)) AS x2, st_y(st_pointn(e.geom, 2))
AS y2,
                    (not connected)::boolean::int * 1000000 AS to_cost,
                    c.first AS rule
        FROM edges e LEFT OUTER JOIN edge_connections c ON e.id = c.second
        WHERE e.group_id = 0 order by e.id',
    1209560, 1209653,
    true, false);
My inner subqery woud have following results:
  id    | source  | target  |         cost         |        x1        |
y1        |        x2        |        y2        | to_cost |  rule
 1087134 |  926686 |  926687 | 2.3299 | 51.4675 | 35.728 | 51.4675 |
35.72805577 |         |
 1209706 | 1039731 | 1039870 | 4.005 | 51.40828 | 35.7239 | 51.4082 | 35.7239 |
1000000 | 1209564
In the results, when a constraint exists, rule and to_cost would not be NULL.
When a turn restriction exists, the results would be exactly like what specified
in the docs (http://www.pgrouting.org/docs/1.x/shooting.html).
However, when I call the shortest_path_shooting_star function, results would not
differ if a rule-and-to_cost exists or not. I have changed directed and
has_reverse_cost parameters but nothing happened.
I was wondering if you guys could help me in this matter. Any advice or even a
clue would be very much appreciated.
Thanks,
* Roozbeh
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110314/ba5cfc10/attachment.html
More information about the Pgrouting-users mailing list
