[pgrouting-users] routing_dd.sql error, inserting on OS X/Homebrew
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Nov 12 16:34:49 EST 2011
On 11/12/2011 4:04 PM, Joe Larson wrote:
> Last night I happily discovered pgRouting had been added to Mac OS X
> Homebrew https://github.com/mxcl/homebrew/pull/8017 and
> https://github.com/charlax/homebrew.
> I was trying to add Driving Distance functions to the database I created
> from a PostGIS template (after I added the routing_core, wrappers and
> topology) as per this post
> http://underdark.wordpress.com/2011/05/13/catchment-areas-with-pgrouting-driving_distance/
> but I got an error when inserting routing_dd.sql:
> psql -d template_routing -f
> /usr/local/Cellar/pgrouting/1.05/share/postlbs/routing_dd.sql
> psql:/usr/local/Cellar/pgrouting/1.05/share/postlbs/routing_dd.sql:28:
> ERROR: could not access file "$libdir/librouting_dd": No such file or
> directory
> psql:/usr/local/Cellar/pgrouting/1.05/share/postlbs/routing_dd.sql:38:
> directory
> Does anyone have some insights on what might be going on here? Thank
> you, Joe.
Joe,
I think the librouting_dd.so gets built separate from the core pgrouting.
cmake -DWITH_DD=ON -DWITH_TSP=ON .
make
make install
If the person that built for OS X did not build with the -DWITH_DD=ON
option then there will not be a library for the sql to link with.
-Steve
More information about the Pgrouting-users
