[pgrouting-users] How to install pgRouting on Mac OSX 10.7 with
PostgreSQL 9.0
Gis Mage
gismage at gmail.com
Tue Oct 11 10:14:15 EDT 2011
Ok, did that.
New error now.
[ 16%] Building CXX object
core/src/CMakeFiles/routing.dir/shooting_star_boost_wrapper.o
i686-apple-darwin11-llvm-g++-4.2: -lgmp: linker input file unused
because linking not done
Linking CXX shared module ../../lib/librouting.so
ld: file not found: POSTGRESQL_EXECUTABLE-NOTFOUND
collect2: ld returned 1 exit status
make[2]: *** [lib/librouting.so] Error 1
make[1]: *** [core/src/CMakeFiles/routing.dir/all] Error 2
make: *** [all] Error 2
Is POSTGRESQL_EXECUTABLE-NOTFOUND an environment variabe?
2011/10/11 William Kyngesburye <woklist at kyngchaos.com>:
> I forgot about that new one, it didn't make it into my notes.
> edit edge_visitors.hpp and delete the line that includes is_same.hpp. it's not really used anyways.
> On Oct 11, 2011, at 4:50 AM, Gis Mage wrote:
>> Hi again!
>> Thanks for the tip. I've changed all includes with /boost in that
>> files to absolute paths like
>> /opt/local/include/boost
>> And now I get a different error:
>> $ make
>> Scanning dependencies of target routing
>> In file included from
>> /opt/distr/pgrouting/lastsrc/pgRouting-pgrouting-a0c6c18/core/src/shooting_star_search.hpp:28,
>> from
>> /opt/distr/pgrouting/lastsrc/pgRouting-pgrouting-a0c6c18/core/src/shooting_star_boost_wrapper.cpp:27:
>> /opt/distr/pgrouting/lastsrc/pgRouting-pgrouting-a0c6c18/core/src/edge_visitors.hpp:9:61:
>> error: /opt/local/include/boost/graph/detail/is_same.hpp: No such file
>> or directory
>> make[2]: *** [core/src/CMakeFiles/routing.dir/shooting_star_boost_wrapper.o]
>> Error 1
>> Looks like the problem is with the is_same.hpp file.
>> When I type:
>> $ locate is_same.hpp
>> /opt/local/include/boost/type_traits/is_same.hpp
>> What else do I need to change?
>> 2011/10/10 William Kyngesburye <woklist at kyngchaos.com>:
>>> Looks like a known issue with recents versions of Boost, some headers were moved.
>>> Edit 3 pgrouting files and change an #include in them:
>>> #include <boost/property_map/vector_property_map.hpp>
>>> core/src/edge_visitors.hpp, shooting_star_relax.hpp:
>>> #include <boost/property_map/property_map.hpp>
>>> On Oct 10, 2011, at 4:50 AM, Gis Mage wrote:
>>>> Hi, list!
>>>> I have a OSX Lion 10.7 computer with PostgreSQL 9.0, installed from MacPorts.
>>>> I'm trying to install pgRouting on top.
>>>> MacPorts version of pgRouting is outdated and is available only for
>>>> postgresql 8.2/8.3.
>>>> Homebrew command
>>>> "brew install pgrouting"
>>>> returns "Error: No available formula for pgrouting"
>>>> When trying to compile from source, as described here:
>>>> http://dirkraffel.com/2011/07/06/pgrouting-on-mac-os-x-10-6-8/
>>>> make command returns an error:
>>>> make
>>>> [100%] Building CXX object
>>>> from
>>>> /opt/distr/pgrouting/lastsrc/pgRouting-pgrouting-a0c6c18/core/src/edge_visitors.hpp:9:42:
>>>> error: boost/graph/detail/is_same.hpp: No such file or directory
>>>> Error 1
>>>> Can anyone help me out with that? I really need to install it on my environment.
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> The equator is so long, it could encircle the earth completely once.
> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
More information about the Pgrouting-users
