[pgrouting-users] [OT] stored procedure performance
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Oct 24 13:54:47 EDT 2011
Hi All,
This is a little off topic, but I did find this issue developing a
postgis related stored procedure.
This is a simple reverse geocoder and it works fine, but here is the
issue and this potentially impacts all procedures that return a record.
So here is the basic query. I added some raise notice to show whats
happening.
select * from imt_rgeo_countyzip(-79.2723,41.2393);
"Clarion";"PA";"42031";"16225";0;0
NOTICE: calling imt_rgeo_countyzip
CONTEXT: PL/pgSQL function "imt_rgeo_countyzip" line 8 at assignment
NOTICE: rr: (Clarion,PA,42031,0), radius: 0.0013
NOTICE: zip: (16225,0), radius: 0.0013
Total query runtime: 81 ms.
1 row retrieved.
So here is the problem! If you call the function this way, it appears to
get called once for each field in the returned record. So if you have 6
fields it actually executes the function 6 times!!!! and the cost goes
up by 6X to 415 ms from 81 ms.
select (imt_rgeo_countyzip(-79.2723,41.2393)).*;
Total query runtime: 415 ms.
1 row retrieved.
I guess this could be that I do not understand what the (..).* syntax is
supposed to be doing.
Thoughts,
-Steve
More information about the Pgrouting-users
