[pgrouting-users] Re: [OT] stored procedure performance [SOLVED]
Stephen Woodbridge woodbri at swoodbridge.com
Mon Oct 24 16:27:12 EDT 2011
Sorry for this noise, this was supposed to go to the postgis list. And I
will post it to that, so you may get yet another copy of it.
On 10/24/2011 4:14 PM, Stephen Woodbridge wrote:
> OK, googling about seems like this is normal but bad behavior. I did
> fine a way to work around this bad behavior.
> This is BAD (function called 6 times):
> select a.*, (b).* from (select x, y, imt_rgeo_countyzip(x,y) as b from
> (select -79.2723 as x, 41.2393 as y) as c) as a;
> This is GOOD (function called 1 time):
> (select -79.2723 as x, 41.2393 as y) as c offset 0) as a;
> It is amazing what you can find in Google :)
> -Steve
> On 10/24/2011 12:04 PM, Stephen Woodbridge wrote:
>> Hi All,
>> This is a little off topic, but I did find this issue developing a
>> postgis related stored procedure.
>> This is a simple reverse geocoder and it works fine, but here is the
>> issue and this potentially impacts all procedures that return a record.
>> So here is the basic query. I added some raise notice to show whats
>> happening.
>> select * from imt_rgeo_countyzip(-79.2723,41.2393);
>> "Clarion";"PA";"42031";"16225";0;0
>> NOTICE: calling imt_rgeo_countyzip
>> CONTEXT: PL/pgSQL function "imt_rgeo_countyzip" line 8 at assignment
>> NOTICE: rr: (Clarion,PA,42031,0), radius: 0.0013
>> NOTICE: zip: (16225,0), radius: 0.0013
>> Total query runtime: 81 ms.
>> 1 row retrieved.
>> So here is the problem! If you call the function this way, it appears to
>> get called once for each field in the returned record. So if you have 6
>> fields it actually executes the function 6 times!!!! and the cost goes
>> up by 6X to 415 ms from 81 ms.
>> select (imt_rgeo_countyzip(-79.2723,41.2393)).*;
>> Total query runtime: 415 ms.
>> 1 row retrieved.
>> Thoughts,
>> -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
