[pgrouting-users] pgrouting installation
Ali Taha ali.taha at ritaj.ps
Tue Sep 13 09:10:12 EDT 2011
Hi Charles,
I got the following result (note that I am using my own ways data):
12058;12057;121;"0105000020E610000001000000010200000012000000D0BAFB60BC8B414
080E097586B883F40F8F2C8ADB68B4140F1CB2CBE78883F4000A4F97AB68B4140C0A7FD39798
83F40A8D05FA6B58B414080C457C47B883F4068ECFF14B58B414072D1E7827E883F40201E03C
BB48B414001C86D6181883F40104D91CAB48B41409896CE4A84883F407853A813B58B4140594
5992987883F40287831A4B58B4140A12BAAE889883F40C85CBB4FB68B4140419F350A8C883F4
0784C7267B68B41401060B4488C883F4058257A4EB78B414080E8F82B8E883F4008C31D68B88
B4140FF96BCB88F883F40089986A9B98B4140704BBFDF90883F40D08E5B06BB8B41400937B29
591883F4088F63471BC8B414076C28DD391883F40888DED4DBD8B414020FE70BD91883F40F82
9FEC4C88B4140B372BD2198883F40";24154;24155;121
12059;12058;151;"0105000020E610000001000000010200000005000000880B2FE4B88B414
00052503B90883F4000E88B85AD8B41406F818066A4883F407883FE35A58B4140B765EAD6B48
83F4050599362988B414070906BE5D3883F4048336500988B4140364027D3D4883F40";24156
;24157;151
Thanks
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Charles Galpin
Sent: Tuesday, September 13, 2011 3:55 PM
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] pgrouting installation
I have used pgrouting on Windows 7 so I think this should work (everything
else installed via stackbuilder)
What do you get for this query?
select * from ways where source = 24154 or target = 24157
charles
On Sep 13, 2011, at 8:37 AM, Daniel Kastl wrote:
Hi Ali,
I may be wrong, and if there are Windows users out there who know it better,
please correct me.
But the binaries for pgRouting were not compiled with Windows 7. They might
work, but not necessarily.
Daniel
On Tue, Sep 13, 2011 at 2:39 AM, Ali Taha <ali.taha at ritaj.ps> wrote:
Dear Daniel,
I downloaded them from http://www.pgrouting.org/download.html  (windows
binaries section pgRouting-1.03_pg-8.4.2)
I have windows 7 OS
Thanks
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Daniel Kastl
Sent: Tuesday, September 13, 2011 6:34 AM
On Mon, Sep 12, 2011 at 11:20 AM, Ali Taha <ali.taha at ritaj.ps> wrote:
Dear All,
I am trying to setup and test pgrouting, I followed the setups but it is
still not working.  If ollowed the following steps:
1-      Copay pgrouting libraries to ..\pgsql\8.4\lib
>From where did you copy them?
Did you compile? Which OS?
Daniel
2-      Execute routing_core.sql and routing_core_wrappers.sql
3-      Create a newtwork:
a.       Added source and target fields
b.      Execute Execute assign_vertex_id('<table>', float tolerance,
'<geometry column', '<gid>')
c.       Added indices
d.      Added reverse_cost column.
Then I used the following query to retrieve records:
SELECT * FROM shortest_path('
SELECT gid as id,
source::integer,
target::integer,
length::double precision as cost
FROM ways',
24154,
24157,
false, false)
the query executes without errors, but return no data. I checked the table
and the records seems OK.
is there a way to validate the database and verify the topology? How to make
sure that the pgrouting library (dlls) are installed and working correctly?
Thanks
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail:  <mailto:daniel.kastl at georepublic.de> daniel.kastl at georepublic.de
Web:  <http://georepublic.de/> http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110913/b2b44241/attachment.html
More information about the Pgrouting-users mailing list
