[pgrouting-users] pgrouting installation
Ali Taha
ali.taha at ritaj.ps
Tue Sep 13 10:41:54 EDT 2011
Hi Carles
Well I guess I am in trouble now J, It seems the data is not ready for
routing.
The paths are not continues because the lines are not breaked at each
intersection.
Is there a tool (or plugin for QGIS) to clean the data by splitting lines at
each intersection?
Thanks
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Charles Galpin
Sent: Tuesday, September 13, 2011 5:15 PM
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] pgrouting installation
Without seeing the headers it's hard to tell is this is ok. I guess it
confirms the start/end points are there anyway.
I can only suggest you manually find a few links that you know are connected
and try route that and see what happens. So start with your link with source
24154 and get the next link with a source that matches the first link target
and so on for a few links and then choose the last target as the end point.
Does that work?
charles
On Sep 13, 2011, at 9:10 AM, Ali Taha wrote:
Hi Charles,
I got the following result (note that I am using my own ways data):
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110913/da72882c/attachment-0001.html
More information about the Pgrouting-users
