[pgrouting-users] pgrouting installation
    Daniel Kastl
    daniel at georepublic.de
    Wed Sep 14 09:28:57 EDT 2011
On Tue, Sep 13, 2011 at 8:41 AM, Ali Taha <ali.taha at ritaj.ps> wrote:
> Hi Carles ****
> Well I guess I am in trouble now J, It seems the data is not ready for
> routing. ****
> The paths are not continues because the lines are not breaked at each
> intersection.
Hi Ali,
Look at this question GIS Stackexchange. Maybe it helps you to solve your
problem:
http://gis.stackexchange.com/questions/13544/split-edges-at-intersections-in-postgis
Daniel
> Is there a tool (or plugin for QGIS) to clean the data by splitting lines
> at each intersection?****
> Thanks****
> *From:* pgrouting-users-bounces at lists.osgeo.org [mailto:
> pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of *Charles Galpin
> *Sent:* Tuesday, September 13, 2011 5:15 PM
> *To:* pgRouting users mailing list
> *Subject:* Re: [pgrouting-users] pgrouting installation****
> Without seeing the headers it's hard to tell is this is ok. I guess it
> confirms the start/end points are there anyway.****
> I can only suggest you manually find a few links that you know are
> connected and try route that and see what happens. So start with your link
> with source 24154 and get the next link with a source that matches the
> first link target and so on for a few links and then choose the last target
> as the end point. Does that work?****
> charles****
> On Sep 13, 2011, at 9:10 AM, Ali Taha wrote:****
> Hi Charles,****
> I got the following result (note that I am using my own ways data):****
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110914/f4b2128a/attachment.html
More information about the Pgrouting-users
