[pgrouting-users] ArcGIS service area with pgRouting
Ian
itangert at gmail.com
Sun Apr 29 09:03:00 EDT 2012
Skipped content of type multipart/alternative-------------- next part --------------
CREATE TYPE networkcalcrs AS
gid integer,
the_geom geometry,
source integer,
target integer
CREATE OR REPLACE FUNCTION _jmsnetworkcalc(double precision, double precision, double precision)
RETURNS SETOF networkcalcrs AS
$BODY$
DECLARE
clickLon ALIAS FOR $1;
clickLat ALIAS FOR $2;
distance ALIAS FOR $3;
sourceID integer;
returnNetwork networkCalcRS;
BEGIN
CREATE TEMP TABLE path
gid integer NOT NULL,
the_geom geometry NOT NULL,
vertex_id integer NOT NULL
CREATE TEMP TABLE network
source integer NOT NULL,
target integer NOT NULL
SELECT INTO sourceID v.id
FROM (SELECT st_transform(ST_SetSRID(ST_Point(clickLon, clickLat), 900913), 4269) As the_geom) As b, vertices_tmp as v
ORDER BY ST_Distance(v.the_geom, b.the_geom)
LIMIT 1;
INSERT INTO path(gid, the_geom, vertex_id)
SELECT rd.gid, rd.the_geom, dd.vertex_id
FROM driving_distance('SELECT gid AS id, source, target, lengthfeet::double precision AS cost
FROM cinciroad', sourceID, distance, false, false) dd, cinciroad rd
WHERE rd.gid = dd.edge_id;
INSERT INTO network(gid, the_geom, source, target)
SELECT rd.gid, rd.the_geom, rd.source, rd.target
FROM path firstPath
CROSS JOIN path secondPath
INNER JOIN cinciroad rd
ON firstPath.vertex_id = rd.source
AND secondPath.vertex_id = rd.target;
FOR returnNetwork IN SELECT * FROM network LOOP
RETURN NEXT returnNetwork;
END LOOP;
END;
$BODY$
LANGUAGE plpgsql VOLATILE
COST 100
ROWS 1000;
ALTER FUNCTION _jmsnetworkcalc(double precision, double precision, double precision) OWNER TO postgres;
SELECT gid, the_geom, source, target FROM _jmsnetworkcalc(X, Y, distance);
More information about the Pgrouting-users
