[pgrouting-users] Problem using TRSP
Tao Romera Martinez taoromera at gmail.com
Thu Aug 30 19:20:14 PDT 2012
Dear Christy, Stephen,
I have tried the query by using a directed graph with reverse cost
(directed_graph and reverse_cost booleans both to "true"), and the
values in the cost column returned by the query are now correct. I
have not performed other checks, such as to see if the route is
actually the one with the lowest cost taking into account turn
restrictions and so. I will look at it later.
Tao
2012/8/31 Stephen Woodbridge <woodbri at swoodbridge.com>:
> The important part is to do the test with no turn restrictions because
> dijkstra  and astar do not do restrictions. So if the route is bad without
> any restrictions then we need to look into what is happening there. Also
> remember the TRSP depending on how it is called also looks at the direction
> of the start and end segments and computes a partial length along those
> segments which the other algorithms do not do and that can impact the
> results if two routes are close to the same length.
> It would really be great if you can do some testing and report your results.
> Thanks,
>   -Steve
> On 8/30/2012 11:27 AM, Christy Nieman wrote:
>> I'll see if I can come up with a simple test case that demonstrates
>> this.  I think it's taking the "wrong" route, but it may possibly be a
>> route of lower cost than the other two algorithms are using.  I'll look
>> into that too.
>> Christy
>> On 08/30/2012 11:22 AM, Stephen Woodbridge wrote:
>>> On 8/30/2012 11:08 AM, Christy Nieman wrote:
>>>> All,
>>>> I'd just like to note that I have noticed this too, and it only seems to
>>>> happen for me if I'm not using a directed graph (e.g. reverse_cost and
>>>> the two booleans to true).
>>> Tao, make sure you try your graph with a directed graph.
>>>> TRSP also seems to not calculate the same routes as A-Star or Dijkstra
>>>> if not using a directed graph.
>>> It is possible that there are multiple paths with the same length, in
>>> which case the result will vary depending on the algorithm sets up the
>>> queue. If you are say that it is compute the "wrong" route as in there
>>> is a shorter route if you are not applying restriction. then you
>>> should probably create a simple test case and fill it with a bug so we
>>> can look into it.
>>> -Steve
>>>> Christy
>>>> On 08/30/2012 07:32 AM, Tao Romera Martinez wrote:
>>>>> Can you think of anything I could try to find the source of the
>>>>> problem?
>>>>> 2012/8/24 Tao Romera Martinez <taoromera at gmail.com>:
>>>>>> Sorry, Stephen, this did not fix the problem. I still have 0 in the
>>>>>> cost column.
>>>>>> 2012/8/23 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>>>>> Try renaming column "cost" and see if the fixes it.
>>>>>>> alter table japan rename column cost to old_cost;
>>>>>>> Let us know if this fixes the problem, because it means we have a
>>>>>>> bug.
>>>>>>> You can rename the column back the way it was with:
>>>>>>> alter table japan rename column old_cost to cost;
>>>>>>> Thanks,
>>>>>>>    -Steve
>>>>>>> On 8/23/2012 2:06 AM, Tao Romera Martinez wrote:
>>>>>>>> Hello Stephen,
>>>>>>>> Thank you very much for your quick answer.
>>>>>>>> The query you asked to me to run gives some rows with cost_car=0,
>>>>>>>> but
>>>>>>>> none of them is in the list of edges returned by
>>>>>>>> turn_restrict_shortest_path.
>>>>>>>> Here is the query result with the cost_car for each edge:
>>>>>>>>      vertex_id | edge_id |    cost    |  cost_car
>>>>>>>>         284867 |  211472 |           0        | 0.07751676
>>>>>>>>         284794 |  211471 |           0        | 0.2359118
>>>>>>>>         134058 |  205895 |        0.15       | 0.14653888
>>>>>>>>         284826 |  205894 |           0        | 0.042989656
>>>>>>>>         131290 |  205893 |           0        | 0.074959315
>>>>>>>>         127938 |  201505 |           0        | 0.054259572
>>>>>>>>         132923 |  201504 |           0        | 0.022826955
>>>>>>>>         282198 |  425307 |           0        | 0.07132499
>>>>>>>>         282197 |  795399 | 0.021921627 |  0.021921627
>>>>>>>>         282276 |  795400 |  0.05221079  |  0.05221079
>>>>>>>>         282035 |  425170 |        0.15       | 0.0967519
>>>>>>>>         282034 |      -1 |           0            |  -
>>>>>>>> I am eager to try to find the reason of this strange behaviour, so
>>>>>>>> tell me if there is anything I can do to figure it out.
>>>>>>>> Best regards,
>>>>>>>> Tao
>>>>>>>> 2012/8/20 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>>>>>>> Please keep the queries on the list.
>>>>>>>>> No, I have no idea, I've never seen anything like that before.
>>>>>>>>> What does this query return?
>>>>>>>>> select count(*) from japan where cost_car=0;
>>>>>>>>> -Steve
>>>>>>>>> On 8/20/2012 7:26 AM, Tao Romera Martinez wrote:
>>>>>>>>>> Dear Stephen,
>>>>>>>>>> I have been trying to use your function for turn restricted
>>>>>>>>>> shortest
>>>>>>>>>> path routing.
>>>>>>>>>> I installed the postgresql functions, prepared a table with the
>>>>>>>>>> turn
>>>>>>>>>> costs, and now I am able to route through a network using turn
>>>>>>>>>> restrictions. Well, almost.
>>>>>>>>>> When I launch a request, the column "cost" contains 0 values
>>>>>>>>>> except
>>>>>>>>>> for the rows where there is a turn (the cost is the one set for
>>>>>>>>>> turns).
>>>>>>>>>> The request is:
>>>>>>>>>> SELECT * FROM turn_restrict_shortest_path(
>>>>>>>>>> 'SELECT id AS id, source::integer, target::integer, cost_car AS
>>>>>>>>>> cost
>>>>>>>>>> FROM japan WHERE japan.geom_way && ST_MakeEnvelope(139.675,
>>>>>>>>>> 35.729,
>>>>>>>>>> 139.705, 35.762)',
>>>>>>>>>> 284867,     -- node_id of start
>>>>>>>>>> 282034,     -- node_id of end
>>>>>>>>>> false,  -- directed graph?
>>>>>>>>>> false,  -- has_reverse_cost?
>>>>>>>>>> 'SELECT to_cost::double precision, teid::integer AS target_id,
>>>>>>>>>> feid||coalesce('',''||via,'''') AS via_path FROM turn_costs WHERE
>>>>>>>>>> teid
>>>>>>>>>> IN (select id FROM japan WHERE japan.geom_way &&
>>>>>>>>>> ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762)) ');
>>>>>>>>>> The ST_MakeEnvelope is just to create a window and limit the
>>>>>>>>>> otherwise
>>>>>>>>>> huge amount of ways.
>>>>>>>>>> The table "japan" looks like:
>>>>>>>>>>     id | osm_id  | osm_name | osm_source_id | osm_target_id |
>>>>>>>>>> clazz |
>>>>>>>>>> flags | source | target | km | kmh | cost | reverse_cost | x1 |
>>>>>>>>>> y1 |
>>>>>>>>>> x2 | y2 | geom_way | cost_car
>>>>>>>>>>      1 | 4847506 |          |      31236733 | 31236584 |
>>>>>>>>>> 11 |
>>>>>>>>>> 1 |  24690 |  24758 | 1.6335903 |   1 | 6.5343612 |    1.6335903 |
>>>>>>>>>> 139.7578 | 35.6437952 | 139.7688252 | 35.6349433 | <snip> |
>>>>>>>>>> 3.2671806
>>>>>>>>>> And the table "turn_costs" looks like:
>>>>>>>>>>     rid | to_cost |  teid  | feid | via
>>>>>>>>>>       1 |    0.15 |     22 |   10 |
>>>>>>>>>>       2 |    0.15 |     21 |   10 |
>>>>>>>>>>       3 |    0.15 |    163 |   10 |
>>>>>>>>>>       4 |    0.15 |     27 |   10 |
>>>>>>>>>>       5 |    0.15 |     26 |   10 |
>>>>>>>>>>       6 |    0.15 |     27 |   11 |
>>>>>>>>>>       7 |    0.15 |     26 |   11 |
>>>>>>>>>>       8 |    0.15 |    229 |   11 |
>>>>>>>>>>       9 |    0.15 | 232698 |   11 |
>>>>>>>>>>      10 |    0.15 |    229 |   12 |
>>>>>>>>>> The result of the query looks like:
>>>>>>>>>>        284867 |  211472 |           0
>>>>>>>>>>        284794 |  211471 |           0
>>>>>>>>>>        284826 |  205894 |           0
>>>>>>>>>>        131290 |  205893 |           0
>>>>>>>>>>        127938 |  201505 |           0
>>>>>>>>>>        132923 |  201504 |           0
>>>>>>>>>>        282198 |  425307 |           0
>>>>>>>>>>        282034 |      -1 |           0
>>>>>>>>>> Do you have an idea about why the "cost" values are 0?
>>>>>>>>>> Thank you very much for your help,
>>>>>>>>>> Tao
>>>>>>>> _______________________________________________
>>>>>>>> Pgrouting-users mailing list
>>>>>>>> Pgrouting-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
