[pgrouting-users] undefined symbol: __gmpq_equal
Dave Potts
dave.potts at pinan.co.uk
Sun Feb 5 06:03:03 EST 2012
On 05/02/12 09:47, Daniel Kastl wrote:
> Hi Dave,
> Do you mean this fix that didn't work for you?
> https://github.com/pgRouting/pgrouting/issues/48
That is the one.
Sorry it did not, but I also noted that I was running postgres 8.4 and
fix is for 9.1. I will upgrade the database first then try it again.
Dave.
> With Ubuntu 11.04 there was such an error as well, but that time this
> small fix was sufficient:
> https://github.com/pgRouting/pgrouting/commit/803092f4103f3ebd7420e598c5ab5231fe40def4
Will try this patch as well.
> Daniel
> On Sun, Feb 5, 2012 at 5:55 PM, Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>> wrote:
> Hi List
> I am running Postgres 8.4.10 on 2.6.38-13-generic #54-Ubuntu, I was
> having some issues with the pgr source code, so I down loaded it and
> attempted to build it.
> Everything seemed to go ok until I tried to use the driving
> distance code
> when I got the diagnostic
> psql:routing_dd.sql:28: ERROR: could not load library
> "/usr/lib/postgresql/9.1/lib/librouting_dd.so":
> /usr/lib/postgresql/9.1/lib/librouting_dd.so: undefined symbol:
> __gmpq_equal
> I have tried the bug fix DD_routing and PostgreSQL 9.1, which seems to
> fixes other peoples problems with the same bug, but it does not
> work on my
> machine.
> Any suggestion as to what to do next?
> >From what I have seen it looks like a version issue/relocation
> error. I
> looked at most of the liabires with nm -C and can not find the '
> missing
> library'
> Dave.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120205/eaf5e9d5/attachment.html
More information about the Pgrouting-users
