[pgrouting-users] Importing for multimodal routes
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Feb 13 15:51:57 EST 2012
Roni,
You might want to jump on this thread and share your experience
implementing Multimodal routing.
Javier,
pgRouting does not support this currently. But in general you assessment
of the problem is correct. I would add "stations" between the various
networks. A station can be represented as an extra node the you have to
go through when changing modes. and the edges between the station and
the different networks can contain costs that are associated with
changing modes. For example, changing between a car and a rental bike,
might add some time and cost to park the car, walk to the rental place
wait in a queue to rent the bike. Or at an airport, you could add 1-2
hours to park and clear security, or to pickup luggage and wait for a
bus, taxis or retrieve your car.
If you are using scheduled modes of transportation, like buses, trains,
airports, etc. then you need to have the schedule information and have
rules like you have to arrive X minutes before departure to get tickets,
etc. so you can assess that at the stations or transfer points. And
during the routing process you have to establish a start time, and then
track the current time as you progress along your route so you can
determine wait time for the next scheduled transfer point. etc. Likewise
if you have time dependent turn restrictions these can be applied as
appropriately as the route progresses and time moves forward from the
start time.
-Steve
On 2/13/2012 11:48 AM, Javier Mr wrote:
> Hi,
> i have been playing around with osm2pgrouting and pgrouting itself, i
> have followed the pgrouting workshop and i have things more clear.
> However i still have a few questions.
> 1. If we have a edge conection nodes A and B and the type of the way
> that allow several tranvel modes (for example 'residential'), for
> example bicicle and car, then 1 edge is created, rigth?
> 2. If i want to limit the type of ways used for routing, that can be
> achieved by the SQL text sentence in the A* algorithm so it just
> retrieve that types of ways, rigth?
> 3. Now, my problem. I don't want to limit the type of vehicle used, but
> the cost of taking a road by car, cicling or by foot isn't the same, and
> even more not all type of ways are suitable for all types of vehicles,
> cars can't go through pedestrian ways. I want to calculate the cheapest
> routing regardless the vehicle used. My first idea is to 'clone' edges
> so i can create disjointed graphs.
> For example A and B are nodes of a way type residential, then some
> edeges are created 1 from A to B and vehicle Car, 2 from A to B and
> vehicle Bike and 3 from A to B and vehicle foot (since is a residential
> way). Now if i compute A* it should giveme the cheapest way and implicit
> is the vehicle used.
> Furthermore, supose 4 nodes, A, B, C, D:
> A: sidewalk and bicicle line and rental bicicle
> B: sidewalk
> C sidewalk, bicicle line and rental bicicle
> D: sidewalk, bicicleline and bicicle parking
> raw costs (reverse al equal):
> A - B: 10
> A - C: 20
> B - D: 10
> C -D: 2
> The topography looks:
> A -- 10 ------B
> 20 10
> C ---- 2 -------D
> If the edeges are cloned depending the vechicle used, it looks like:
> x0 : node is sidewalk. Cost multiplier 1 (doesn't modify cost)
> x1: node is public bike. Cost multiplier 0.2 (divide cost by 5)
> x2: node is private bike. Cost multiplier 0.2
> A0 --- 10 ---- B0
> 20 10
> C0 ---- 2 ----- D0
> A1
> 4
> C1
> A2
> 4
> C2 ----- 0.5 ... D2
> And :
> A0 - A1: 0 (cost)
> C0 - C1: 0
> D0 - C2: 0
> Now if my initial state is A2 it implies i am in A with my private bike
> so if my goal is C0 (by foot) i have to park by bike in D in order to
> achieve the goal.
> Or if initial state is A0 and goal state is C0 i would do: A0 - A1 - C1
> - C0, so i have rented a public bike and i have also returned it.
> Of course i'm aware that this increase the state space for A*, the other
> aproach is to modify how A* expand nodes.
> If you know a better approach to achieve this please share. If not, i
> was planning to modify how the network topology is created, thats why i
> ask in the first mail for a easy to used OSM XML libreary, and since
> it's only for importing i don't really care about the programming language.
> Maybe the easiest way is to modify osm2pgrouting so it imports the
> topology i described?
> Hope it's easy to inderstand.
> Best regards.
> Javier.
> *De:* Stephen Woodbridge <woodbri at swoodbridge.com>
> *Para:* pgrouting-users at lists.osgeo.org
> *Enviado:* Jueves 9 de febrero de 2012 18:49
> *Asunto:* Re: [pgrouting-users] Importing for multimodal routes
> On 2/9/2012 11:00 AM, Javier Mr wrote:
> > Hi,
> > i'm planning to use pgRouting for multimodal routing. I know
> there is a
> > branch of pgRouting for MMPTR, but until i gather more
> information about
> > it i'm trying to avoid it.
> > What i'm planning is to make several graph, each one for each type of
> > vehicle, pedestrians, bikes, etc... and each line of bus, train,
> subway,
> > etc... Then connect this graphs by making edeges from, for example, a
> > bus station to the closest pedestrian edege with length of 0.
> This way i
> > would have a big state set for the A* algorithm that should perform
> > multimodal planing. Is there a reason why this shoulnd't be done?
> > I have some doubts about how osm2pgrouting woks. I have seen that
> OSM is
> > capable of storing all this things, but i don't know if osm2pgrouting
> > import all that into the DB, does it?.
> > There are some libraries that work with OSM XML format, any in
> > particular that you recomend?
> There are a few tools that will load OSM data into a postgres databse
> that pgRouting can use. You might want to read the documenation:
> http://www.pgrouting.org/docs/tools.html
> -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
