[pgrouting-users] Re:Some ideas for upcoming GSoC
Stephen Woodbridge woodbri at swoodbridge.com
Thu Feb 16 16:34:46 EST 2012
On 2/16/2012 2:46 PM, sittichai choosumrong wrote:
> Dear all,
> First of all I would like to thank you Prof.Venkatesh Raghavan to
> introduce me again to this mailing list.
> About using AHP with pgRouting, I was started using AHP for assign a
> priority weigth to the elements that depending on their perceived
> relative importance for computing route result.
> For example, If we need to find the route from start point to the
> destination point such as hospital in case of emergency route. The
> elements were used for a judgments are Distance, Speed limit, Road
> width, Road type, Junction delay, etc. (If we first  thinking only about
> the road condition). Then, from AHP analysis we can get the priority
> weights values like this;
>    Criteria            | Priority (%)
> |   distance         |   15.89%
> |  Speel limit       |    8.82%
> |  Road width      |    4.83%
> |  Road type       |    6.78%
> | Junction delay  |    12.88%
> |   Sum              |   100%
> Next step, I need to integrate this values with road netwrok attribute
> data to compute the minimum cost for a route result.
> Any ideas how to do this process?
> Best regards,
> Sittichai
Hi Sittichai,
In general when dealing with graph algorithm you have a cost associated
with traversing an edge or possible a node. So in your example above,
the problem becomes trivial is you can unify you analysis into a common
denominator like time.
So the cost to traverse an edge could be represented as time and then
all you have to do is convert your attributes into an equivalent impact
in seconds.
cost = distance/speed + junction delay + etc
you reference speed limit, but what you really want to know is what is
the average speed at the time you plan to take the route. If you have
traffic feed data or historical speed-by-time data this might be useful.
Road width and road type are again trying to assess some average speed,
or whether or not the vehicle in use is classed to use that road.
Since the graph edges are passed to the solver via a query, you can
construct a complex query the joins multiple tables and dynamically
computes the edge weights. If You have multiple destinations, then these
can all get extracted and you can add the additional analysis of the end
conditions to the various destination drive times.
So think in terms of some unified cost function that returns a number
that can be used as a cost. The only condition is that any two edges
that get the same cost from your function will have equal weights in the
solution.
Hope this helps,
   -Steve
PS: Please trim excess text if you reply from a digest.
More information about the Pgrouting-users mailing list
