[pgrouting-users] Some ideas for upcoming GSoC
Max Weninger
max.weninger at gmail.com
Thu Feb 23 18:57:10 EST 2012
Hi
Has the "pgrouting team" ever thought about implementing
a routing solution based on "contraction hierarchies"
Details about the concepts can be found here
http://algo2.iti.kit.edu/routeplanning.php
http://code.google.com/p/monav/wiki/ContractionHierarchies
Example implementaions e.g. here
http://project-osrm.org/
Routing with such engines is extremely fast (milisecs)
even for really large networks
Regards
max
On Thu, 16 Feb 2012 14:52:46 +0900
Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp> wrote:
> Dear All,
> As most of you must be aware, the
> Google Summer of Code 2012 has been announced [1,2]
> Some ideas that comes to my mind are
> 1) Implementing of map-matching algorithms as of the pgRouting
> function. Python code for the algorithms that we implemented in 2010
> (See http://cs-test.ias.ac.in/cs/Downloads/article_45523.pdf) could be
> made available and the main work would be to integrate/improve
> them for implementation as pgRouting and/or SORouting (see item 2
> below)
> 2) Implementing routing as a service. a) Use Web Feature Service
> (WFS) as input b) implement routing functions as Web Processing
> Service (WPS) c) Publish
> routing result as WFS. That would be SORouting (Service Oriented
> Routing instead
> of pgRouting. Since I am also a ZOO-Project (www.zoo-project.org) PSC
> member which is a OGC compliant open-source WPS implementation, I
> would take this opportunity to promote the use of ZOO for
> implementing SORouting.
> 3) Route selection based on multi-criteria decision model to enable
> alternative
> route selection based on conditions at the destination. For example,
> route to
> the nearest hospital depending not only upon road conditions but also
> conditions at several destination hospitals (bed availability,
> availability of
> medicare specialists, availability of ICU etc). The condition of
> destination could be implemented using the OGC SOS standard.
> Regarding multi-criteria decision using AHP (analytical hierarchy
> process). There are several literature available [3],[4]. My student
> Sittichai (who writes
> on the pgRouting users list) has already started some work and could
> perhaps take up the work if he finds a mentor.
> Best
> Venka
> P.S. Also Cc to ZOO-PSC since there may be some mentors there to help
> with the WPS implementation for SORouting
> Prof. Venkatesh Raghavan
> Osaka City University
> Japan
> [1]http://www.google-melange.com/gsoc/homepage/google/gsoc2012
> [2]
> http://google-opensource.blogspot.com/2012/02/google-summer-of-code-2012-is-on.html
> [3] http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=5567840
> [4]
> http://www.tandfonline.com/doi/abs/10.1080/13658810601135692#preview
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
