[pgrouting-users] Problem with way restrictions in shooting
star if you have more then one rule for an edge
Max Weninger
max.weninger at gmail.com
Wed Jan 11 20:13:39 EST 2012
Hi again
It does not only look good - its perfect :)
All my turn restriction "testcases" work as expected
and give the correct routing.
Thanks a lot for the work and if you need some help
e.g for testing just give me a note.
Regards
max
On Thu, 12 Jan 2012 02:02:48 +0100
Max Weninger <max.weninger at gmail.com> wrote:
> Hi
> Tried the new trsp code and it looks good :)
> I havent tried complex turn restrictions though
> But just a quick question:
> Is it normal that it always returns -1 as the last edge id?
> regards
> max
> On Wed, 11 Jan 2012 11:28:38 -0500
> Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> > > I will take a look at the "new" code asap :)
More information about the Pgrouting-users
