[pgrouting-users] Shortest Path Shooting-Star Ignore Reverse Cost
Jorge Eliécer Osorio Caro jorgeliecer.osorio at gmail.com
Mon Jan 30 15:04:23 EST 2012
Thanks Steve for you request i testing the new branch tos see what happend.
2012/1/30 Stephen Woodbridge <woodbri at swoodbridge.com>
> Jorge,
> I have posted a few times on this problem, you can check the archives. The
> short story is the shooting star is broken. I think the last version that
> worked is 1.03. In my posts is also some information on a new algorithm
> turn_restricted_shortest_path (trsp) that is in a branch. The current code
> in a git branch works but is likely to see changes before it is released,
> but we do not have a release plan yet.
> -Steve
> On 1/30/2012 2:30 PM, Jorge Eliécer Osorio Caro wrote:
>> Im having a issue when try to calculate the shortest path using turn
>> restricctions this functions ignores the reverse_cost param.
>> here the SQL:
>> |SELECT
>>     FROM
>>         shortest_path_shooting_star(
>>             'SELECT
>>                 routing.network.segment as id,
>>                 routing.network.source,
>>                 routing.network.target,
>>                 routing.network.length as cost,
>>                 routing.network.reverse_length as reverse_cost,
>>                 routing.network.x1,
>>                 routing.network.y1,
>>                 routing.network.x2,
>>                 routing.network.y2,
>>                 routing.network.rule,
>>                 routing.network.to_cost
>>             FROM
>>                 routing.network',
>>             -- node_from, node_to
>>             15365,
>>             15366,
>>             --15242,
>>             false,  -- directed
>>             true-- reverse_cost
>> this generate that route:
>> http://cl.ly/**242E2T0A2C410F1S0F3g <http://cl.ly/242E2T0A2C410F1S0F3g>
>> that method generate the route but it ignores the one_way restriction ,
>> the restriction is ok, but take a route where ignores that.
>> now in the next image i need the marked red lines are the correct route
>> because the 15229 and 15228 has both ways.
>> http://cl.ly/**3t2O38343F0F0C0o3P2c <http://cl.ly/3t2O38343F0F0C0o3P2c>
>> here how look my table:
>> id source target cost reverse:cost rule to_cost x1, y1, x2, y2
>> 15245 9082 9150 0.02 100.00021 15214 101.00021 -74.79981 10.94605
>> -74.7996 10.94605
>> how i cant fix that i compiled the last version of pgrouting from git
>> repo.
>> ______________________________**_________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120130/0c003737/attachment-0001.html
More information about the Pgrouting-users mailing list
