[pgrouting-users] Which method to use?
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jan 30 17:44:21 EST 2012
On 1/30/2012 5:26 PM, Dave Potts wrote:
> Is there a generic introduction which list what each of the route method
> does and why I would what to use it with a given data set/
There is a tutorial
     http://www.pgrouting.org/docs/foss4g2008/index.html
and here is my assessment:
Dijkstra solution:
This is a node based solution that converts a graph into a tree and the
tree has all nodes that are reachable from the start node. This is used
in the driving distance solution and has other applications where you
might want the cost to get to multiple node. The default output is to
only return that path from the start node to the destination node.
Astar search solution:
This is a modified Dijkstra solver that uses a Heuristic to direct the
solver to the destination node. As a result, the graph solution is
typically faster the Dijkstra because you only have to solve part of the
graph needed to find the solution.
ShootingStar solution:
This is an edge based solver. IT IS CURRENT BROKEN! and as best as I can
tell the last version that worked is v1.03. It is current running
significantly (2-4x slower than the above two solutions). The reason it
was created was because it support turn restrictions.
These are the main three solvers.
We just added a new branch TRSP (turn restricted shortest path) that is
(will be) an alternative to ShootingStar. It is a modified Dijkstra
solver, that takes turn restrictions and is only slight slower than
Dijkstra.
In addition to these there is a TDSP (time dependent shortest path) that
I believe is based off of Dijkstra solver, that allows costs to be
dynamically selected based on a start time and time along the route, so
if you have costs like average speed per time of day, the correct cost
can be used when solving the problem.
And we have a couple more Google Summer of Code add-ons to pgrouting
that I'm not sure I can do justice to explain.
-Steve
More information about the Pgrouting-users mailing list
