[pgrouting-users] Shortest Path Shooting-Star Ignore Reverse Cost
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jan 30 21:26:06 EST 2012
On 1/30/2012 5:47 PM, Jorge Eliécer Osorio Caro wrote:
> Steve,
> This is my route:
> http://cl.ly/2v3G05442o3h2H0G2L0l
> i have restricted turn going from 9151, 9082.
> how i need to set this in my table restricctions.
> SQL:
> drop table if exists routing.route;
> create table if not exists routing.route(
> nid serial not null
> ) with oids;
> Select AddGeometryColumn('routing', 'route', 'geometry', '4326',
> 'LINESTRING', 2);
> insert into routing.route(geometry)
> SELECT
> routing.network.geometry
> FROM
> SELECT
> FROM
> turn_restrict_shortest_path(
> 'SELECT
> routing.network.segment as id,
> routing.network.source,
> routing.network.target,
> routing.network.length as cost,
> routing.network.reverse_length as reverse_cost
> FROM
> routing.network',
> -- node_from, node_to
> 9151,
> 9082,
> --15242,
> false, -- directed
> true, -- reverse_cost
> 'SELECT
> routing.restrictions.target_id,
> routing.restrictions.to_cost,
> routing.restrictions.via_path
> FROM
> routing.restrictions'
> ) as route inner join routing.network on
> route.edge_id = routing.network.segment
> Table looks like:
> target_id to_cost via_path
> 9082 1000 9151, 9083
> i missing somehting?
Yes, eventually we will have documentation. TRSP uses nodes (currently)
to define the the route start and end points, but restrictions are
defined in terms of edges. So you restriction table should look like:
12736 1000 12832
So read this as traveling from edge 12832 to 12736 costs 1000.
If you wanted to say that you can not make a U-turn from 12829 to 12736
via 12832 then you could create a restriction like
12736 1000 12832,12829
-Steve
> 2012/1/30 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> On 1/30/2012 4:20 PM, Stephen Woodbridge wrote:
> The turn restrictions are handled differently in TRSP. You need
> to have
> a table like:
> target_edge_id (int4), to_cost(float8), via_path (text)
> This is a replacement for the rule and at the moment
> via_path := reverse(rule)
> so if your rule = 1,2,3,4 then via_path = 4,3,2,1
> I think that this will eventually change to be consistent with
> shooting_star and the rule.
> I believe that the way to interpret this is to apply the to_cost
> if the
> current edge it target_edge_id and prior edge was 4, and 3
> before that,
> and 2 before that, and 1 before that. So the cost would NOT be
> applied
> given this rule if the path was current_edge, 4, 3, 7 for example.
> You may have multiple rules for a given target_edge_id.
> In my database, I have a table like this:
> CREATE TABLE trsp_rest
> to_cost double precision,
> target_id integer,
> via_path text,
> the_geom geometry,
> "rule" text,
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom)
> = 'LINESTRING'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
> WITH (
> OIDS=FALSE
> the geometry is just a copy of the target_id geometry that I can use
> to spatially restrict the restrictions to that of my query, but it
> is not required. You could also use a join to do the same thing.
> And then for the turn_restrict_sql you can pass something like:
> 'select to_cost, target_id, via_path from trsp_rest'
> where the_geom && <bbox of query>'
> -Steve
> -Steve
> On 1/30/2012 4:00 PM, Jorge Eliécer Osorio Caro wrote:
> Hi Steve,
> I compile that version but i dont know very well the params
> that i need
> to send to:
> now we have via_path, means that edges where i can have
> access? its in
> replacement of rule?
> now we have that parameter to:
> sql text,
> source_id integer,
> target_id integer,
> directed boolean,
> has_reverse_cost boolean,
> turn_restrict_sql text)
> turn_restrict_sql what i need to pass there?
> i have something like this:
> SELECT * FROM turn_restrict_shortest_path( 'SELECT
> routing.network.segment as id, routing.network.source,
> routing.network.target, routing.network.length as cost,
> routing.network.reverse_length as reverse_cost,
> routing.network.x1,
> routing.network.y1, routing.network.x2, routing.network.y2,
> routing.network.rule as via_path, routing.network.to_cost FROM
> routing.network', -- node_from, node_to 15365, 15366,
> --15242, false, --
> directed true, -- reverse_cost 'ż?' )
> thanks steve.
> <mailto:woodbri at swoodbridge. com
> <mailto:woodbri at swoodbridge.com>>>
> Jorge,
> I have posted a few times on this problem, you can check the
> archives. The short story is the shooting star is broken. I
> think
> the last version that worked is 1.03. In my posts is also some
> information on a new algorithm turn_restricted_shortest_path
> (trsp)
> that is in a branch. The current code in a git branch works
> but is
> likely to see changes before it is released, but we do not
> have a
> release plan yet.
> -Steve
> On 1/30/2012 2:30 PM, Jorge Eliécer Osorio Caro wrote:
> Im having a issue when try to calculate the shortest path
> using turn
> restricctions this functions ignores the reverse_cost param.
> here the SQL:
> |SELECT
> FROM
> shortest_path_shooting_star(
> 'SELECT
> routing.network.x1,
> routing.network.y1,
> routing.network.x2,
> routing.network.y2,
> routing.network.rule,
> FROM
> routing.network',
> 15365,
> 15366,
> --15242,
> false, -- directed
> true-- reverse_cost
> this generate that route:
> http://cl.ly/ 242E2T0A2C410F1S0F3g
> <http://cl.ly/ 242E2T0A2C410F1S0F3g
> <http://cl.ly/242E2T0A2C410F1S0F3g>>
> that method generate the route but it ignores the one_way
> restriction ,
> the restriction is ok, but take a route where ignores that.
> now in the next image i need the marked red lines are the
> correct route
> because the 15229 and 15228 has both ways.
> http://cl.ly/ 3t2O38343F0F0C0o3P2c
> <http://cl.ly/ 3t2O38343F0F0C0o3P2c
> <http://cl.ly/3t2O38343F0F0C0o3P2c>>
> here how look my table:
> id source target cost reverse:cost rule to_cost x1, y1, x2, y2
> 15245 9082 9150 0.02 100.00021 15214 101.00021 -74.79981
> 10.94605
> -74.7996 10.94605
> how i cant fix that i compiled the last version of pgrouting
> from git repo.
> ______________________________ _________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo. org
> <mailto:Pgrouting-users at lists. osgeo.org
> <mailto:Pgrouting-users at lists.osgeo.org>>
> http://lists.osgeo.org/ mailman/listinfo/pgrouting- users
> <http://lists.osgeo.org/ mailman/listinfo/pgrouting- users
> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>>
More information about the Pgrouting-users
