[pgrouting-users] pgrouting workshop
Pedro Costa pedrocostaarma at sapo.pt
Tue Jul 10 08:17:28 PDT 2012
Thanks again Daniel.
Now i'm trying everything but i get this error in firebug:
"NetworkError: 500 Internal Server Error -
http://mydomain.pt/routing/php/pgrouting.php?startpoint=89314.61677724583%20123959.32146482218&finalpoint=90696.99736799067%20123514.05047980057&method=SP"
I don't have to define password of database in php file?
Em 10-07-2012 13:22, Daniel Kastl escreveu:
> On Tue, Jul 10, 2012 at 12:47 PM, Pedro Costa <pedrocostaarma at sapo.pt
> <mailto:pedrocostaarma at sapo.pt>> wrote:
>     I'm confused.
>     My map is in srs 900913 and my tables  in postgis are in srs 27492.
>     In workshop example the points are converted to srs 4326 why?
>     Because the funcion findnearestedge needs the data in srs 4326?
>     If yes, i just need to convert to my table srs (900913) correct?
> Hi Pedro,
> OSM data imported with osm2pgrouting or osm2po are WGS84 (4326), so
> this is what you have in the database.
> OpenLayers uses World Mercator projection (900913 and there are some
> aliases), so start point and end point in the workshop need to be
> transformed to 4326.
> In your case you had to replace 4326 with 27492, I guess, assuming
> that you use OpenLayers (GeoExt) and your dataset.
> Daniel
>     Thanks
>              [1] var startpoint = layer.features[0].geometry.clone();
>                  startpoint.transform(epsg_900913, epsg_4326);
>                  var finalpoint = layer.features[1].geometry.clone();
>                  finalpoint.transform(epsg_900913, epsg_4326);
>     Em 10-07-2012 11:09, Daniel Kastl escreveu:
>>     Hi Pedro,
>>     In which projection are your start and end point?
>>     You need to use ST_transform(<geom>,<srid>) if the projection is
>>     different.
>>     In the workshop the data is in 4326 (WGS84) and so you can find
>>     this SRID in the SQL statement.
>>     Daniel
>>     On Tue, Jul 10, 2012 at 11:42 AM, Pedro Costa
>>     <pedrocostaarma at sapo.pt <mailto:pedrocostaarma at sapo.pt>> wrote:
>>         I'm trying to adapt this function (findnearestedge) [1] to my
>>         routing data that are in srs 27492.
>>         Someone can help me with that?
>>         thanks
>>         [1]
>>         $startEdge = findNearestEdge($startPoint);
>>          $endEdge   = findNearestEdge($endPoint);
>>           function findNearestEdge($lonlat) {
>>         SELECT gid, source, target, the_geom,
>>                           distance(the_geom, GeometryFromText(
>>                                'POINT(".$lonlat[0]."
>>         ".$lonlat[1].")', 4326)) AS dist
>>                          FROM ".TABLE."
>>                          WHERE the_geom && setsrid(
>>         'BOX3D(".($lonlat[0]-0.1)."
>>         ".($lonlat[1]-0.1).",
>>         ".($lonlat[0]+0.1)."
>>         ".($lonlat[1]+0.1).")'::box3d, 4326)
>>                          ORDER BY dist LIMIT 1"
>>         Em 10-07-2012 09:33, Daniel Kastl escreveu:
>>>         Hi Pedro,
>>>         The years before it was always available on OSGeo server:
>>>         http://download.osgeo.org/pgrouting/foss4g2010/
>>>         It seems I forgot to place the 2011 workshop there as well.
>>>         The workshop documentation source is on Github:
>>>         https://github.com/pgRouting/workshop
>>>         So all you're missing is the sample data. But you can
>>>         download any OSM data or even use the sample data of 2010.
>>>         In case you're using Ubuntu/Debian you can install last
>>>         years workshop as a package easily:
>>>         https://launchpad.net/~georepublic/+archive/pgrouting/+packages
>>>         <https://launchpad.net/%7Egeorepublic/+archive/pgrouting/+packages>
>>>         It contains the sample data of Denver as well. Or you
>>>         download the tarball [1] and extract it.
>>>         Or, you use OSGeo Live DVD. It contains the workshop as well:
>>>         http://live.osgeo.org/en/quickstart/pgrouting_quickstart.html (see
>>>         "What's next" at the end of the page).
>>>         Hope that helps,
>>>         Daniel
>>>         [1]
>>>         https://launchpad.net/~georepublic/+archive/pgrouting/+files/pgrouting%2Bworkshop_0.6.1.orig.tar.gz
>>>         <https://launchpad.net/%7Egeorepublic/+archive/pgrouting/+files/pgrouting%2Bworkshop_0.6.1.orig.tar.gz>
>>>         On Tue, Jul 10, 2012 at 10:15 AM, Pedro Costa
>>>             Hi guys,
>>>             I'm playing with pgrouting workshop of FOSS4G 2011.
>>>             There is any link to download the workshop material?
>>>             Thanks
>>>             Pedro
>>>             _______________________________________________
>>>             Pgrouting-users mailing list
>>>             Pgrouting-users at lists.osgeo.org
>>>             <mailto:Pgrouting-users at lists.osgeo.org>
>>>             http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>         Georepublic UG & Georepublic Japan
>>>         eMail: daniel.kastl at georepublic.de
>>>         <mailto:daniel.kastl at georepublic.de>
>>>         Web: http://georepublic.de <http://georepublic.de/>
>>>         Pgrouting-users at lists.osgeo.org  <mailto:Pgrouting-users at lists.osgeo.org>
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120710/ebd47e18/attachment-0001.html>
More information about the Pgrouting-users mailing list
