[pgrouting-users] implement directions
Pedro Costa pedrocostaarma at sapo.pt
Tue Jul 31 07:39:53 PDT 2012
Hi Guys,
I began to work on directions but i have a few questions:
A) I see that the result of pgrouting query returns the lines in route
order so I
  have a column with street names and i want to get the name of the
first line to make a instruction like that:
"Start the journey by' + 'street name of the first line'
Do you know how I can select the name of the first line?
B) I'm trying to determine the bearing for instructions like 'turn
right' or 'turn left 'but here's my question based on image attached
(example). The black line are the network and the yellow the route.
To measure bearing with points, I think i have to do with the first
point of line one and with the last point of line two right?
If i try to determine the bearing of point 1 to point 2 the result will
be 0 right? Despite, in reality, we have to make a route of 90 degrees
of line one to line two.
I'm thinking right? Can someone help me with that?
I hope that you understand my questions.
Thanks
Em 30-07-2012 19:09, Stephen Woodbridge escreveu:
> On 7/30/2012 1:24 PM, Greg Allensworth wrote:
>> On 7/30/2012 9:57 AM, Pedro Costa wrote:
>>> Em 30-07-2012 17:54, Pedro Costa escreveu:
>>>> Hi guys,
>>>> Can someone point to me some links or information about implement
>>>> driving directions in a pgrouting project?
>>> With driving directions i mean information about the select route like
>>> "turn right" ...
>> http://postgis.refractions.net/pipermail/postgis-users/2007-November/017768.html
>> That's what I was going to use as a start, when I get to that phase of
>> our routing system. The "left" or "right" would be the difference
>> between the two lines' azimuth: if the difference is positive, and more
>> than 0.15 radians then it's a slight right, more than .50 radians it's a
>> sharp right, if the difference is negative then it's a left, if the
>> difference is <0.15 radians in either direction then it's not even a
>> turn that I care to mention, ....
>> But I'm sure someone has developed and documented more of the math here,
>> beyond these first steps. I'm sure I'll be asking a few questions along
>> these lines, in a few weeks when I get to that phase.
> Hi Guys,
> I have written a lot about this and implemented it for various
> projects. Here is a google search that should find most of what I have
> written:
> https://www.google.com/search?q=woodbridge+pgrouting+driving+directions
> Start by reading some of these and if you have questions I am willing
> to help. The big issue with writing a "generic" solution is that it
> really needs to be customized around the data you are using. The
> pgrouting part gives you a list of edges, the driving directions
> starts with this list of edges and then has to analyze things like are
> the names the same on adjacent edges so you can compress the edges
> into a single maneuver, when you get to an intersection, do the
> analysis that Greg mentions to explicate the instruction, etc.
> If you want to see an integrated example of it look at:
> http://gis.imaptools.com/routing/leaddog/?zoom=11&lat=33.86651&lon=35.51184&layers=B0TTTF&start=35.493583%2033.826664&stop=35.565174%2033.864285&method=STS&lang=eng
> You might think about this as a family of functions like
> -- basic pgrouting query, returns edge ids
> select * from shortest_path(...);
> -- convert route edge ids into maneuvers
> select * from maneuvers(shortest_path(...));
> -- convert maneuvers into textual directions
> select * from explicate(maneuvers(shortest_path(...)));
> The maneuvers are generic definition of an instruction. The
> explication can then be a table driven instruction generation based on
> a fixed set of maneuvers. If you want to have multi language support
> like my example above, you just change the table from English template
> to say French, German, Arabic, etc.
> Hope this helps,
>   -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120731/0acdd10e/attachment-0001.png>
More information about the Pgrouting-users mailing list
