[pgrouting-users] Assign Vertex ID time
Ian itangert at gmail.com
Fri Jun 1 12:42:34 PDT 2012
On 6/1/12 1:21 PM, Stephen Woodbridge wrote:
> On 6/1/2012 11:45 AM, Ian wrote:
>> Hi all,
>> Does anyone have any estimations on how long it would take to run
>> assign_vertex_id on the entire Census TIGER dataset for the United
>> States?
>> Say you had a 2.6ghz intel core 2 duo processor and 8gb of RAM? Or has
>> anybody done this and have a time and their computer's specs?
> I'm going to take a wild guess that it is something in the ball park
> of 1 week. You have a secondary problem in that this is all done in a
> single stored procedure call, which means that it is all done in a
> single transaction. This might be an issue as the transaction will
> become extremely large.
> You might look at using the TNIDF and TNIDT which are the Tiger assign
> node numbers.
> So how are you planning on using this data with pgRouting? Tiger does
> not have attributes like oneway streets, zlevels at intersections or
> turn restrictions all of which are needed to do useful routing planning.
> Are you aware the using tiger you will generate routes like enter an
> exit of highway, drive to the top of an overpas and make a left hand
> turn onto the underpass 20 feet below you, etc?
> It can be useful for some restricted routing uses where you can
> overlook these issues but in general it is not suitable for most
> routing tasks.
> -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Thanks for the input.
So TNIDF & TNIDT can be imported to the 'source' & 'target' columns as
long as they are properly linked to the endpoint geometry?
My project has to do with walking in cities so I'm thinking that I will
be able to overlook routing issues associated with driving....I will
have to make some assumptions though (sidewalks ped-xings), but streets
in cities tend to be walkable.
I noticed that OSM data has some attribution TIGER data does not, maybe
I should look there too.
Even if I clip the streets to only include the areas I really need
(cities with a population of over 10,000), I'm guessing that would still
be the majority of all the streets (maybe 1/3 or more?)
Well... if I end up doing assign_vertex_id on a large dataset I'll
report back any useful results,
ian
More information about the Pgrouting-users mailing list
