[pgrouting-users] postgis 2.0 and postgresql 9.1
Ricardo Bayley ricardo.bayley at gmail.com
Mon Jun 4 07:02:43 PDT 2012
Is there a build for postgis under windows in a  64bit enviroment ?
thanks
2012/5/23 Pedro Costa <pedrocostaarma at sapo.pt>
> Hello James,
> Of course. I have win7 64 bits with postgresql 9.1.2 and postgis 1.5.3.
> I'm only copy the binaries [1] to the C path.
> Now I will try with postgis 2.0 and return the results.
> Thanks
> [1] https://github.com/sanak/**pgrouting/downloads<https://github.com/sanak/pgrouting/downloads>
> Em 23-05-2012 11:18, James David Smith escreveu:
>  Hi Pedro,
>> Would be very grateful if you'd provide a short summary of what you
>> did to get it all working - along with links to the download packages?
>> Thanks
>> James
>> On 23 May 2012 11:13, Pedro Costa<pedrocostaarma at sapo.pt>  wrote:
>>> Perfect....works....
>>> Thanks
>>> Em 22-05-2012 23:42, Sanak escreveu:
>>> Hi Pedro,
>>> If you use pgRouting on Windows, download module from
>>> here(https://github.com/sanak/**pgrouting/downloads<https://github.com/sanak/pgrouting/downloads>-
>>> pgRouting-git-sanak-mingw_**20120310_pg-9.1(x86).zip).
>>> Because above module was based on git master
>>> branch(https://github.com/**pgRouting/pgrouting<https://github.com/pgRouting/pgrouting>)
>>> after justjkk's latest
>>> commit(2011/08/08), some drnextgis's sql fixes had already applied after
>>> release 1.0.5,
>>> but more drnextgis's fix(https://github.com/**
>>> pgRouting/pgrouting/pull/50<https://github.com/pgRouting/pgrouting/pull/50>)
>>> may
>>> be necessary.
>>> Hi Jorge,
>>> Thanks for your report about PostgreSQL version incompatibility.
>>> I will check about this problem.
>>> Sorry for my english.
>>> Regards,
>>> 2012/5/23 Jorge Fuentes<jfuentes at estudiantes.**uci.cu<jfuentes at estudiantes.uci.cu>
>>>> Was just easy like double clik and next next...
>>>> but a had to download binaries from (I don't remember)
>>>> .. but I'm sure that you will find that url in older post or googlering
>>>> it..
>>>> and be sure that you had postgreSQL 9.1.3 32 bit because i try with
>>>> 9.1.1
>>>> and not work because a dll change from that version to 9.1.3
>>>> remember to execute .slq file from pgrouting
>>>> best regards
>>>> El 22/05/2012 12:35 pm, Pedro Costa escribió:
>>>>> Em 22-05-2012 16:48, Jorge Fuentes escreveu:
>>>>>> Yes I had them install and running PosgreSQL 9.1.3, postGIS 2.0 and
>>>>>> pgrouting on win 7-32bits
>>>>> Hi Jorge,
>>>>> It was necessary to any change in code? Or were the normal procedures?
>>>>> Thanks
>>>>> ______________________________**_________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>>>> 10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS
>>>>> INFORMATICAS...
>>>>> CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
>>>>> http://www.uci.cu
>>>>> http://www.facebook.com/**universidad.uci<http://www.facebook.com/universidad.uci>
>>>>> http://www.flickr.com/photos/**universidad_uci<http://www.flickr.com/photos/universidad_uci>
>>>> INFORMATICAS...
>>>> http://www.uci.cu
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120604/ee1153df/attachment.html>
More information about the Pgrouting-users mailing list
