[pgrouting-users] very hight costs
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 11 11:08:02 PDT 2012
This page is in error:
http://www.pgrouting.org/docs/howto/mapserver.html
The result of the dijkstra_sp() function returns a record set like:
vertex_id | edge_id | cost
which does not contain a geometry column.
To get the geometry column which is in your dourol table you need to
join the results back to that table, change you DATA statement to
something like:
DATA "the_geom from (
select b.the_geom, a.* from
(SELECT * FROM shortest_path('SELECT gid AS id, source::int4,
target::int4, length::double precision AS cost,
FROM dourol',3, 7, false, false)) as a
dourol b where a.edge_id=b.gid) AS
foo using unique gid using srid=-1"
Also for what it is worth, if you are also using OpenLayers, I typically
write a simple PHP ajax handler to interact with postgresql and format
the results as XML or JSON then use an OpenLayers geometry feature to
display the route. This way I compute the route once and can pan an zoom
on the result in OpenLayers without having to requext a new route until
I want to change the route. Look at this page to get some ideas:
http://gis.imaptools.com/routing/leaddog/?zoom=11&lat=33.86651&lon=35.51184&layers=B0TTTF&start=35.493583%2033.826664&stop=35.565174%2033.864285&method=STS&lang=eng
-Steve W
On 6/11/2012 1:59 PM, Pedro Costa wrote:
> Thank you to all.
> I resolved with a where statement but i also will try using '-1'.
> I have another question, anybody know examples of using pgrouting with
> mapserver?
> Or know information about that....
> Thanks
> On 06/11/2012 06:05 PM, Max Weninger wrote:
>> Hi
>> On Mon, 11 Jun 2012 11:03:33 -0400
>> Stephen Woodbridge<woodbri at swoodbridge.com> wrote:
>>> I'm pretty sure TRSP allows -1 for a cost and drops that edge
>>> internally.
>> Yes
>> If you look at the code starting at line 361
>> Edges are only "used" if>=0.0
>> if(cur_edge.m_dCost>= 0.0)
>> if(cur_edge.m_dReverseCost>= 0.0)
>> Regards
>> max
>>> -Steve W
>>> On 6/11/2012 10:45 AM, James David Smith wrote:
>>>> Hi Pedro,
>>>> Could you someone temporarily remove the roads from the network
>>>> instead? When you do the select statement to query your network, you
>>>> could do a WHERE statement which ignores certain roads?
>>>> Might not work, just thinking out loud....
>>>> James
>>>> On 11 June 2012 15:40, Pedro Costa<pedrocostaarma at sapo.pt> wrote:
>>>>> Em 11-06-2012 15:38, Steve Horn escreveu:
>>>>>> high cost (such as 99999999
>>>>> Hello Steve,
>>>>> With me the hight cost is a problem because my network have few
>>>>> roads....
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
