[pgrouting-users] assign_vertex_id error
Dave Potts dave.potts at pinan.co.uk
Tue Jun 12 08:01:15 PDT 2012
You database has 11 entries which do not have a correct geometry column,
I suspect that this may be causing you some problems.
select * from roads_line where the_geom is NULL will list all the problems
delete from  roads_line where the_geom is null
will permanently remove these data items from your database.
I can not say that this is the root cause of your problem but I suspect
that its not helping you.
Annu Anurag wrote:
> No sir. I just ran the query and it returned the following result.
> VSDelhidb=# SELECT count(*) FROM roads_line where the_geom is NULL;
>  count
>     11
> (1 row)
> What do I do sir?
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
