[pgrouting-users] pgRouting with SQL server?
Daniel Kastl daniel at georepublic.de
Wed Jun 20 07:51:10 PDT 2012
Hi Christina,
pgRouting requires PostGIS and PostgreSQL, so you can't install it on a
different database management system.
Eventually it's possible to use a new PostgreSQL feature called "Foreign
data wrappers" [1] [2] to access data outside PostgreSQL, which allows to
treat the data source like a table. But I haven't tried this yet and can't
tell it works for SQL Server nor how it performs.
Daniel
[1] http://www.postgresql.org/docs/9.1/static/ddl-foreign-data.html
[2] http://wiki.postgresql.org/wiki/Foreign_data_wrappers
On Wed, Jun 20, 2012 at 4:33 PM, Mitsakou, Christina <
christina.mitsakou at kcl.ac.uk> wrote:
> Hi everyone****
> I would like to ask if any pgRouting user has any experience on the
> following:****
> **1)      **Would it be possible to use pgRouting with other database
> management system rather than PostgreSQL (e.g. SQL server)?****
> **2)      **If we install on a server both systems (PostgreSQL, SQL
> server) would it produce any server failure?****
> I appreciate your comments on the above points.****
> Thanks****
> Christina****
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120620/ee7c0bfc/attachment.html>
More information about the Pgrouting-users mailing list
