[pgrouting-users] sort result
Max Weninger
max.weninger at gmail.com
Tue Mar 20 09:02:30 EDT 2012
Hi
On Tue, 20 Mar 2012 13:50:46 +0100
"Sven Schroeter" <schroeter at netgis.de> wrote:
> Second Question:
> Is it possible to set a "via" point directly in the SQL? With
> dijkstra_sp_directed is it only possible to set a start and a
> endpoint.
I guess with "via" you mean something like a "waypoint"?
"Normally" that would be two queries
start -> via + via -> end
Then combine the result lists to get the complete path
Regards
max
More information about the Pgrouting-users
