[pgrouting-users] Test case - can't find route
Hugo hfpmartins at gmail.com
Tue May 22 18:46:22 EDT 2012
Hello again,
Thanks Stephen. As i firstly suspected and you pointed out it was all
related with the topology.
Thnaks a lot for the help.
Cheers,
Hugo
On Mon, May 14, 2012 at 4:13 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hugo,
> You data MUST be noded. That means that the end of one segment MUST NOT
> hit the interior of a connecting edge. The connect in edge must be split so
> there is a node there.
> o - nodes
> Invalid: two edges A and B where the end of A is on edge B but there is no
> node on B that matches the end of A:
>           o
>           A
>           o
> o-----B-----------------o
> Valid: To fix the above issue, you must split edge B into B and C where
> the end of A touches B. So the intersection of A, B and C is one node with
> the same coordinate values.
>           o
>           A
> o-----B----o------C-----o
> -Steve
> On 5/14/2012 10:47 AM, Hugo wrote:
>> Hello all,
>> Thanks a lot for your answers. They were really helpful.
>> Using the initial test case, when building the topology i was using a
>> very small tolerance and that's why pgrouting was not able to calculate
>> a route. Increasing that tolerance would solve the problem but raise
>> other problems such as: at junctions the route would go back to nearest
>> edge point and then again forward to complete the route (see image
>> below, calculated route in blue).
>> Inline image 2
>> I have also decided to try to split all the multilinestrings to simple
>> linestrings (made up of only two points). These scenario gives the best
>> results when calculating the best route and allows for smaller
>> tolerance. However, obviously it takes a higher computational cost.
>> Do you think that this last approach would not be advisable for
>> calculating routes to be show on a webmap?
>> Thanks once again.
>> Cheers,
>> Hugo
>> On Fri, May 11, 2012 at 1:52 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>    Hi Hugo,
>>    I have not been able to load this test case up yet, but my intuition
>>    is that the topology is a problem as you suggest. Can you post the
>>    results of this query and what tolerance did you use with
>>    assign_vertex_id();
>>    select gid, source, target, x1, y1, x2, y2 from roads;
>>    Tolerance needs to be set to a value in the unit of the coordinate
>>    system you are using for your edges. So if you are using degrees
>>    thena reasonable tolerance= 0.000001 if you are use 6 decimals of
>>    precision. Or if your data is in meters or feet then 1.0 might be
>>    appropriate. Basically the tolerance is the maximum distance between
>>    two end points that you want to be considered as the same point.
>>    -Steve
>>    On 5/11/2012 4:27 AM, Hugo wrote:
>>        Hello all,
>>        I've been using the same workshop to try out pgrouting. And i
>>        have also
>>        tried with the a-star algorithm which is giving the same
>>        results. Here
>>        are the queries i'0ve tried:
>>        select * from shortest_path_astar(
>>        'select gid as id,
>>             source::integer,
>>             target::integer,
>>             length::double precision as cost,
>>             length::double precision as reverse_cost,
>>             x1, y1, x2, y2
>>             from roads',
>>             8, 5, true, true
>>        select * from shortest_path(
>>        'select gid as id,
>>             source::integer,
>>             target::integer,
>>             from roads',
>>             8, 5, true, true
>>          From what i was able to check, i thiink this might be related
>>        with the
>>        topology that is built with the function assign_vertex_id() but i'm
>>        really not sure. I think i will try to explode the road network
>> into
>>        simple lines (having only two points defining each line) and try
>>        it out
>>        again to see if that makes any changes.
>>        Any addiotional hints?
>>        Cheers,
>>        Hugo
>>        On Fri, May 11, 2012 at 7:21 AM, Javier Mr
>>        <javiersdevmail at ymail.com <mailto:javiersdevmail at ymail.**com<javiersdevmail at ymail.com>
>>        <mailto:javiersdevmail at ymail. com
>>        <mailto:javiersdevmail at ymail.**com <javiersdevmail at ymail.com>>>>
>> wrote:
>>            Hi,
>>            i would sugest using A-Star algorithm (specially form large
>>            datasets). As Daniel has said the query would be very
>>        usefull. Check
>>            the directed graph and has_reverse_cost booleans parameters
>>        in the
>>            core query. Just in case this is a link to a workshop, the one
>> i
>>            used to get pgrouting up and running:
>>        http://workshop.pgrouting.org/ chapters/shortest_path.html#
>>        dijkstra
>>        <http://workshop.pgrouting.**org/chapters/shortest_path.**
>> html#dijkstra<http://workshop.pgrouting.org/chapters/shortest_path.html#dijkstra>
>>            Regards.
>>            Javier
>>                *De:* Daniel Kastl <daniel at georepublic.de
>>        <mailto:daniel at georepublic.de>
>>        <mailto:daniel at georepublic.de <mailto:daniel at georepublic.de>**> >
>>                *Para:* pgRouting users mailing list
>>        <pgrouting-users at lists.osgeo. org
>>        <mailto:pgrouting-users at lists.**osgeo.org<pgrouting-users at lists.osgeo.org>
>>        <mailto:pgrouting-users at lists. osgeo.org
>>                *Enviado:* Viernes 11 de Mayo de 2012 1:23
>>                *Asunto:* Re: [pgrouting-users] Test case - can't find
>> route
>>                Hello Hugo,
>>                Thank you for reporting this!
>>                Could you also share your query?
>>                Daniel
>>                On Fri, May 11, 2012 at 2:32 AM, Hugo
>>        <hfpmartins at gmail.com <mailto:hfpmartins at gmail.com>
>>        <mailto:hfpmartins at gmail.com <mailto:hfpmartins at gmail.com>>**>
>> wrote:
>>                    Hello all,
>>                    This is my first post to this mailing list as i have
>>        just
>>                    started to look into pgrouting more deeply.
>>                    When making some routing with this fantastic piece
>>        of work,
>>                    on a big network i was able to find some porblems where
>>                    pgrouting is not finding any route. I attach a very
>>        simple
>>                    and small data set (roads and vertices_tmp as
>>        shapefiles)
>>                    that illustrates the problem. If you look into teh
>> image
>>                      below, pgrouting is not able to calculate route
>>        between
>>                    point 8 and 5. I'm using the Dijkstra algorithm and
>> have
>>                    built the topology as explained in the docs. I'm using
>>                    pgrouting 1.0.3 under postgres 8.4 with postgis 1.5.
>>        What to
>>                    do in the topology so that a route can be found and
>>        how can
>>                    i do it in a bulk form to apply to a much bigger
>>        roads dataset?
>>                    Thanks in advance. Cheers,
>>                    Hugo
>>                    Inline image 1
>>                    Hugo Martins
>>                    ______________________________ _________________
>>                    Pgrouting-users mailing list
>>        Pgrouting-users at lists.osgeo. org
>>        <mailto:Pgrouting-users at lists.**osgeo.org<Pgrouting-users at lists.osgeo.org>
>>        <mailto:Pgrouting-users at lists. osgeo.org
>>        http://lists.osgeo.org/ mailman/listinfo/pgrouting- users
>>        <http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>                Georepublic UG & Georepublic Japan
>>                eMail: daniel.kastl at georepublic.de
>>        <mailto:daniel.kastl@**georepublic.de<daniel.kastl at georepublic.de>
>>        <mailto:daniel.kastl@ georepublic.de
>>                Web: http://georepublic.de <http://georepublic.de/>
>>        Hugo Martins
>> Hugo Martins
>> ______________________________**_________________
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
Hugo Martins
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120522/830fe14f/attachment-0001.html
More information about the Pgrouting-users mailing list
