[pgrouting-users] FW: Multiple queries in a row
Daniel Kastl
daniel at georepublic.de
Thu Nov 22 11:13:21 PST 2012
You're probably missing the packages to compile, because this isn't
mentioned in the tutorial.
There it installs the packages from the Launchpad repository.
You need to install are the following packages:
build-essential, postgresql-server-dev-9.1, cmake, libboost-graph-dev,
gaul-devel and libcgal7 or libcgal8 (I don't remember the version)
Daniel
On Fri, Nov 23, 2012 at 3:51 AM, Iñigo Vázquez
<ivgwildchild666 at hotmail.com>wrote:
> My Ubuntu version is 12.04 LTS. And in PostgreSQL installation I used the
> following sentences:
> - sudo apt-get install postgresql-9.1
> - sudo apt-get install postgresql-client-9.1
> - sudo apt-get install postgresql-contrib-9.1
> - sudo apt-get install postgresql-server-dev-9.1
> - sudo apt-get install pgadmin3
> Also for pgrouting funcionallity I followed this tutorial
> http://workshop.pgrouting.org/chapters/installation.html
> I'm not sure if this pakects are standard or no.
> From: daniel at georepublic.de
> Date: Fri, 23 Nov 2012 02:33:40 +0900
> To: pgrouting-users at lists.osgeo.org
> Subject: Re: [pgrouting-users] FW: Multiple queries in a row
> Which version of Ubuntu do you use (your screenshots look like Ubuntu,
> right)?
> In general compiling works as described in the documents, but some
> releases come with new versions of dependencies or cause other troubles.
> Also, do you use standard PostgreSQL packages?
> Daniel
> On Thu, Nov 22, 2012 at 7:47 PM, Iñigo Vázquez <
> ivgwildchild666 at hotmail.com> wrote:
> Could you explain me how to build "pgrouting" github project?
> I have no experience with cmake tool.
> Thanks!
> Date: Wed, 21 Nov 2012 22:44:13 +0900
> Sorry, the Wiki page says you need it.
> But for DD (driving Distance) you need to install (compile) GAUL.
> Daniel
> On Wed, Nov 21, 2012 at 10:40 PM, Daniel Kastl <daniel at georepublic.de>wrote:
> On Wed, Nov 21, 2012 at 10:15 PM, Iñigo Vázquez <
> Nice! I think this should be valid for my case. But I'm having some
> troubles in compilation/installation.
> I've downloaded the .zip archive from github and I extracted it. From
> "cmake" folder I execute this command "cmake -DWITH_DD=ON" and then, when
> I try to execute this one "sudo make install" isn't work (there's no
> rule for install target).
> Am I doing something wrong?
> Well, that's hard to tell without more details about the error and your
> OS, etc..
> But have you tried without "-DWITH_DD=ON"? Do you need it?
> Daniel
> Date: Wed, 21 Nov 2012 20:39:59 +0900
> There is something, but it didn't make it yet into pgRouting master branch:
> https://github.com/pgRouting/pgrouting/wiki/APSP
> You can find it in this branch:
> https://github.com/pgRouting/pgrouting/tree/gsoc-tdsp
> Daniel
> On Wed, Nov 21, 2012 at 8:05 PM, Tao Romera Martinez <taoromera at gmail.com>wrote:
> Hi Iñigo,
> I needed to do something similar to what you are trying to do some time
> ago and asked in the list. Unfortunately, it is not possible to retrieve
> several shortest paths in one run. It is certainly possible to reduce the
> time needed to perform the shortest path routing between a set of nodes,
> but for this the code of the shortest_path C function should be modified to
> fetch the road network data it needs from the DB only once and then perform
> the routing algorithm several times.
> Tao
> 2012/11/21 Iñigo Vázquez <ivgwildchild666 at hotmail.com>
> Thanks for your reply, but in my case the shortest path doesn`t interest
> me. I need the shortest paths from one given node to each others beacuse
> then I want to calculate a path taking into account a given time limit.
> Something like in the "Traveling Salesman Problem" but with Time Window.
> Thanks!
> From: gunnar at tradlosetrondheim.no
> Date: Wed, 21 Nov 2012 11:08:03 +0100
> Subject: Re: [pgrouting-users] Multiple queries in a row
> CC: ivgwildchild666 at hotmail.com
> Hello,
> I do not know the answer to you question, but I might know an workarround
> if you are only interrested in the shortest of them.
> We use a hack to find the path to the closest node of a set of nodes.
> Basically we tweak the query which builds the graph to rename all nodes
> which are applicable to some id which cannot be found in the graph elsewere
> (e.g. -1), and the search for the path to this node.
> (NB: this could/would give strange beahviour if used with astar)
> Best regards Gunnar
> Dear all,
> I need to obtain a set of nearest nodes from a given location (maybe 30 or
> 40). Then I need to calculate the shortest path from the given node from
> each others. It means to execute shortes_path query multiple times in a
> row, wich takes about 2 seconds (1 query 2 seconds: 30 queries 60 -> too
> long).
> SELECT * FROM shortest_path('
> SELECT id AS id,
> source::int4 AS source,
> target::int4 AS target,
> cost::float8 AS cost
> FROM tt_2po_4pgr',275742,274494,
> false,
> false)
> What would be the best way to do this in a reasonable time?
> Thank in advance!
> Pd: excuse my english
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Gunnar Rangøy System developer Trådløse Trondheim / Wireless Trondheim
> tradlosetrondheim.no +47 99 36 06 99
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> _______________________________________________ Pgrouting-users mailing
> list Pgrouting-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20121123/97fe1136/attachment-0001.html>
More information about the Pgrouting-users
