[pgrouting-users] Where to get the data for the Workshop?
Luís de Sousa
luis.a.de.sousa at gmail.com
Wed Apr 3 01:35:42 PDT 2013
Hi Nicolas, thanks for the info.
I waited 3 hours yesterday, but I'll leave it processing overnight today.
It would be nice to have some sort of progress indicator.
Regards,
Luís
On 3 April 2013 10:26, Nicolas Najdovski <
nicolas.najdovski at student.uclouvain.be> wrote:
> Hi Daniel!
> You just have to wait...
> For only a small city it takes about one hour with a regular disk... To
> process belgium it takes four days.
> With a SSD disk it's much faster since it mainly limited by the speed of
> the hard disk.
> Cheers
> Nicolas
> Le 03/04/13 09:47, Luís de Sousa a écrit :
> Hi Daniel, thank you for the reply.
> I successfully downloaded the area required for the workshop from
> bbbike.org. Unfortunately osm2pgrouting is not able to process this data
> set, it is hanging up after creating the Classes table (see below). Is
> there any way to run osm2pgrouting in verbose mode? Or somehow get some
> more information on may be going wrong?
> Thank you,
> Luís
> On 28 March 2013 16:43, Daniel Kastl <daniel at georepublic.de> wrote:
>> On Fri, Mar 29, 2013 at 12:14 AM, Luís de Sousa <
>> luis.a.de.sousa at gmail.com> wrote:
>>> Hello everyone,
>>> I'm just starting with pgRouting, following the workshop tutorial
>>> available on line. I've installed all the required packages and
>>> created the databases successfully, but unfortunately I'm not able to
>>> get the data. Here's the result using the command in the workshop
>>> pages:
>>> $ wget --progress=dot:mega -O "sampledata.osm"
>>> http://jxapi.openstreetmap.org/xapi/api/0.6/*[bbox=-105.2147,39.5506,-104.594,39.9139]
>>> Warning: wildcards not supported in HTTP.
>>> --2013-03-28 15:37:59--
>>> Resolving jxapi.openstreetmap.org (jxapi.openstreetmap.org)...
>>> 128.40.168.100
>>> Connecting to jxapi.openstreetmap.org
>>> (jxapi.openstreetmap.org)|128.40.168.100|:80... connected.
>>> HTTP request sent, awaiting response... 502 Proxy Error
>>> 2013-03-28 15:52:59 ERROR 502: Proxy Error.
>>> In face of this I went to the OSM wiki to check if this address was
>>> correct. I thus tried it the way they suggest there:
>>> http://api.openstreetmap.org/api/0.6/map?bbox=-105.2147,39.5506,-104.594,39.9139
>>> --2013-03-28 15:55:01--
>>> Resolving api.openstreetmap.org (api.openstreetmap.org)...
>>> 193.63.75.99, 193.63.75.100, 193.63.75.103, ...
>>> Connecting to api.openstreetmap.org
>>> (api.openstreetmap.org)|193.63.75.99|:80... connected.
>>> HTTP request sent, awaiting response... 400 Bad Request
>>> 2013-03-28 15:55:01 ERROR 400: Bad Request.
>>> Still no luck, so I tried with JOSM, as suggested in the workshop
>>> page. Using the same bounding box I get this error:
>>> The OSM server 'http://api.openstreetmap.org/api/0.6/' reported a bad
>>> request.
>>> The area you tried to download is too big or your request was too large.
>>> Either request a smaller area or use an export file provided by the
>>> OSM community
>>> Apparently the API is not digesting well this bounding box. Is there
>>> any other way I could get the data to follow on with the Workshop?
>> Eventually the API has changed (the current workshop was mainly
>> written for FOSS4G 2011).
>> There are various ways though to download OSM data, ie:
>> http://download.geofabrik.de/
>> http://download.bbbike.org/osm/
>> http://developer.mapquest.com/web/products/open/xapi
>> So I'm not sure the current API error is temporary. Could be that the
>> XAPI is not available anymore:
>> http://wiki.openstreetmap.org/wiki/Xapi
>> If you find a working solution I'm glad to update the workshop.
>> Daniel
>>> Thank you,
>>> Luís
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
> Pgrouting-users mailing listPgrouting-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130403/9192c2d0/attachment.html>
More information about the Pgrouting-users
