[pgrouting-users] pgRounting with PostGIS 2.0
Daniel Kastl
daniel at georepublic.de
Tue Apr 9 04:05:16 PDT 2013
> On 9 April 2013 12:25, James David Smith <james.david.smith at gmail.com>wrote:
>> This pledge was met, so I am hoping/expecting that we may see it
>> distributed as part of the extensions list soon:
>> http://www.pledgebank.com/pgRoutingWindows
>> James
>> On 9 April 2013 11:21, Luís de Sousa <luis.a.de.sousa at gmail.com> wrote:
>> > Dear all,
>> > Out of the box, pgRounting doesn't work with PostGIS 2.0. All PostGIS
>> > functions now have the st_ prefix to their name, hence most (all?) of
>> the
>> > pgRouting scripts don't run. I see there is a pull request opened for
>> some
>> > time to solve this issue:
>> > https://github.com/pgRouting/pgrouting/pull/72
>> > Is this pull being considered? Or will pgRouting remain attached to
>> PostGIS
>> > 1.5? Would it be possible to create a PostGIS 2.0 compatible branch?
>> > Thank you,
A new release is currently worked on.
There is lots of discussion on the developer list and if you want to try
out, you could checkout from Github repository and compile using the
following branch:
https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0
There are also experimental automated Windows builds since a few hours ago:
http://www.bostongis.com/blog/index.php?/archives/215-pgRouting-1.07dev-windows-binaries-available-for-PostgreSQL-9.2-32-bit-and-64-bit.html
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130409/a1645277/attachment.html>
More information about the Pgrouting-users
