[pgrouting-users] pgRounting with PostGIS 2.0
Pedro Costa
pedrocostaarma at sapo.pt
Tue Apr 9 04:06:14 PDT 2013
Hi Luis,
I'm using postgis 2.0 with pgrouting.
I have to change some code of pgrouting (because the 'st_') but works.
But i'm using only two functions:
shortest_path
assign_vertex_id
SO: Ubuntu Server
Pedro
Em 09-04-2013 11:33, Luís de Sousa escreveu:
> Thank you for the tip James.
> I don't use Winblows, nor it will ever be the base of our servers. I'd
> also prefer to keep these changes within the present repo and not
> splinter the project.
> Regards,
> Luís
> On 9 April 2013 12:25, James David Smith <james.david.smith at gmail.com
> <mailto:james.david.smith at gmail.com>> wrote:
> This pledge was met, so I am hoping/expecting that we may see it
> distributed as part of the extensions list soon:
> http://www.pledgebank.com/pgRoutingWindows
> James
> On 9 April 2013 11:21, Luís de Sousa <luis.a.de.sousa at gmail.com
> <mailto:luis.a.de.sousa at gmail.com>> wrote:
> > Dear all,
> > Out of the box, pgRounting doesn't work with PostGIS 2.0. All
> PostGIS
> > functions now have the st_ prefix to their name, hence most
> (all?) of the
> > pgRouting scripts don't run. I see there is a pull request
> opened for some
> > time to solve this issue:
> > https://github.com/pgRouting/pgrouting/pull/72
> > Is this pull being considered? Or will pgRouting remain attached
> to PostGIS
> > 1.5? Would it be possible to create a PostGIS 2.0 compatible branch?
> > Thank you,
> > Luís
> > Pgrouting-users mailing list
> > Pgrouting-users at lists.osgeo.org
> <mailto:Pgrouting-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130409/0718c206/attachment.html>
More information about the Pgrouting-users
