[pgrouting-users] pgRounting with PostGIS 2.0
Luís de Sousa
luis.a.de.sousa at gmail.com
Sun Apr 14 09:55:32 PDT 2013
I could help testing it. I'll set up an environment and let you know.
Best,
Luís
On 14 April 2013 17:07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Dave, Luis,
> I am merging Dave's ksp branch into sew-devel-2_0 branch. Once I have all
> the files merged into my tree and integrated with my cmake, I may need some
> help testing it out and/or debugging it.
> I should have something commited and pushed later today.
> Thanks,
> -Steve
> On 4/14/2013 1:04 AM, Dave Potts wrote:
>> Hi
>> I added some code for doing k shortest routes, see
>> https://github.com/pgRouting/**pgrouting/pull/75<https://github.com/pgRouting/pgrouting/pull/75>
>> The code that does the ksp part is taken from an another open source
>> project, I just added the interface layer to postgres.
>> If there is a 'better/faster' way of doing the same thing ......
>> Dave.
>> On 10/04/13 16:24, Luís de Sousa wrote:
>>> Dear Steve,
>>> I work regularly with pgpsql and PostGIS 2.0, and did a good deal of C
>>> coding back in the 1990s.
>>> I'd rather start with simpler tasks and then build from there if I
>>> find the resources.
>>> Regards,
>>> Luís
>>> On 10 April 2013 15:33, Stephen Woodbridge <woodbri at swoodbridge.com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>> wrote
>>> Luis,
>>> Funding would be great if you can arrange it, K-Shorest path is
>>> one of the algorithms that we would like to add to 2.0 so we might
>>> be able to accelerate getting that moved into sew-devel-2_0 branch.
>>> Regarding contributing, do you have any area(s) that you would
>>> like to work on. We can use effort in all areas. I do not where
>>> your skills are on the spectrum from developer <----> user, but
>>> there is no shortage of tasks across the board.
>>> Regards,
>>> -Steve
>>> ______________________________**_________________
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130414/d9a21815/attachment.html>
More information about the Pgrouting-users
