[pgrouting-users] Server Crash in debug code in BiDirAStar.cpp in dev branch
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Tue Aug 13 18:14:11 PDT 2013
On 8/13/2013 5:13 PM, Dave Potts wrote:
> If you compile the BiDirAStar with the DEBUG enabled
> The following block of code is switched in (lines 33-39)
> #define DBG(format, arg...) \
>      dbg = fopen("/tmp/sew-debug", "a"); \
>      fprintf(dbg, format,  ## arg); \
>      fclose(dbg);
> #else
> If the file /tmp/sew-debug can not be written to, the open will fail,
> the fprintf on the following line will then be invoked on a null
> pointer, with the result that program will crash, you need to say
> something like
>      if(dbg != NULL ){\
>          fclose(dbg);\
> #else
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Dave,
Thanks! good catch on that. I will make that change and push it soon.
-Steve
More information about the Pgrouting-users
