[pgrouting-users] OSM2pgRouting failling silently
Luís de Sousa
luis.a.de.sousa at gmail.com
Fri Aug 30 06:54:09 PDT 2013
Hi again Daniel, thanks for the reply. Unfortunately that package is not
installing (see below).
How can I provide more feedback on this error? Thanks,
Luís
$ sudo apt-get upgrade osm2pgrouting
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages have been kept back:
cgi-mapserver gdal-bin grass-core libgeos-c1 libgeos-dev libmapserver
libqgis1.8.0 linux-generic
linux-headers-generic linux-image-generic mapserver-bin php5-mapscript
postgis python-gdal python-mapscript
python-qgis python-qgis-common qgis qgis-common qgis-plugin-grass
qgis-plugin-grass-common qgis-providers
qgis-providers-common texmaker
The following packages will be upgraded:
apparmor apparmor-utils cmake cmake-curses-gui cmake-data dh-apparmor
gnome-control-center
gnome-control-center-data libapparmor-perl libapparmor1
libgnome-control-center1 libpci3 osm2pgrouting pciutils
postgresql-9.1-pgrouting
15 upgraded, 0 newly installed, 0 to remove and 24 not upgraded.
Need to get 9,879 kB of archives.
After this operation, 1,852 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Get:1 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main apparmor
amd64 2.7.102-0ubuntu3.8 [357 kB]
Get:2 http://ppa.launchpad.net/georepublic/pgrouting-unstable/ubuntu/
precise/main cmake-curses-gui amd64 2.8.9-0ubuntu1~ubuntu12.04.1~ppa1 [1,375
kB]
Get:3 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main pciutils
amd64 1:3.1.8-2ubuntu6 [259 kB]
Get:4 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main libpci3
amd64 1:3.1.8-2ubuntu6 [25.9 kB]
Get:5 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main libapparmor1
amd64 2.7.102-0ubuntu3.8 [37.7 kB]
Get:6 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main
libapparmor-perl amd64 2.7.102-0ubuntu3.8 [30.1 kB]
Get:7 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main
apparmor-utils amd64 2.7.102-0ubuntu3.8 [112 kB]
Get:8 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main
libgnome-control-center1 amd64 1:3.4.2-0ubuntu0.12 [78.7 kB]
Get:9 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main
gnome-control-center-data all 1:3.4.2-0ubuntu0.12 [1,121 kB]
Get:10 http://ppa.launchpad.net/georepublic/pgrouting-unstable/ubuntu/
precise/main cmake amd64 2.8.9-0ubuntu1~ubuntu12.04.1~ppa1 [4,711 kB]
Get:11 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main
gnome-control-center amd64 1:3.4.2-0ubuntu0.12 [661 kB]
Get:12 http://de.archive.ubuntu.com/ubuntu/ precise-updates/main dh-apparmor
all 2.7.102-0ubuntu3.8 [8,966 B]
Get:13 http://ppa.launchpad.net/georepublic/pgrouting-unstable/ubuntu/
precise/main cmake-data all 2.8.9-0ubuntu1~ubuntu12.04.1~ppa1 [806 kB]
Get:14 http://ppa.launchpad.net/georepublic/pgrouting-unstable/ubuntu/
precise/main postgresql-9.1-pgrouting amd64 2.0.0-rc1-ppa20~precise1 [244
kB]
Get:15 http://ppa.launchpad.net/georepublic/pgrouting-unstable/ubuntu/
precise/main osm2pgrouting amd64 2.0.0-beta-ppa4 [52.5 kB]
Fetched 9,879 kB in 1s (5,245 kB/s)
Preconfiguring packages ...
(Reading database ... 486462 files and directories currently installed.)
Preparing to replace apparmor 2.7.102-0ubuntu3.7 (using
.../apparmor_2.7.102-0ubuntu3.8_amd64.deb) ...
Unpacking replacement apparmor ...
Preparing to replace pciutils 1:3.1.8-2ubuntu5 (using
.../pciutils_1%3a3.1.8-2ubuntu6_amd64.deb) ...
Unpacking replacement pciutils ...
Preparing to replace libpci3 1:3.1.8-2ubuntu5 (using
.../libpci3_1%3a3.1.8-2ubuntu6_amd64.deb) ...
Unpacking replacement libpci3 ...
Preparing to replace libapparmor1 2.7.102-0ubuntu3.7 (using
.../libapparmor1_2.7.102-0ubuntu3.8_amd64.deb) ...
Unpacking replacement libapparmor1 ...
Preparing to replace libapparmor-perl 2.7.102-0ubuntu3.7 (using
.../libapparmor-perl_2.7.102-0ubuntu3.8_amd64.deb) ...
Unpacking replacement libapparmor-perl ...
Preparing to replace apparmor-utils 2.7.102-0ubuntu3.7 (using
.../apparmor-utils_2.7.102-0ubuntu3.8_amd64.deb) ...
Unpacking replacement apparmor-utils ...
Preparing to replace cmake-curses-gui 2.8.7-0ubuntu5 (using
.../cmake-curses-gui_2.8.9-0ubuntu1~ubuntu12.04.1~ppa1_amd64.deb) ...
Unpacking replacement cmake-curses-gui ...
Preparing to replace cmake 2.8.7-0ubuntu5 (using
.../cmake_2.8.9-0ubuntu1~ubuntu12.04.1~ppa1_amd64.deb) ...
Unpacking replacement cmake ...
Preparing to replace cmake-data 2.8.7-0ubuntu5 (using
.../cmake-data_2.8.9-0ubuntu1~ubuntu12.04.1~ppa1_all.deb) ...
Unpacking replacement cmake-data ...
Preparing to replace libgnome-control-center1 1:3.4.2-0ubuntu0.11 (using
.../libgnome-control-center1_1%3a3.4.2-0ubuntu0.12_amd64.deb) ...
Unpacking replacement libgnome-control-center1 ...
Preparing to replace gnome-control-center-data 1:3.4.2-0ubuntu0.11 (using
.../gnome-control-center-data_1%3a3.4.2-0ubuntu0.12_all.deb) ...
Unpacking replacement gnome-control-center-data ...
Preparing to replace gnome-control-center 1:3.4.2-0ubuntu0.11 (using
.../gnome-control-center_1%3a3.4.2-0ubuntu0.12_amd64.deb) ...
Unpacking replacement gnome-control-center ...
Preparing to replace postgresql-9.1-pgrouting 1.05-1~precise2 (using
.../postgresql-9.1-pgrouting_2.0.0-rc1-ppa20~precise1_amd64.deb) ...
Unpacking replacement postgresql-9.1-pgrouting ...
dpkg: error processing
/var/cache/apt/archives/postgresql-9.1-pgrouting_2.0.0-rc1-ppa20~precise1_amd64.deb
(--unpack):
trying to overwrite '/usr/lib/postgresql/9.1/lib/librouting_dd.so', which
is also in package postgresql-9.1-pgrouting-dd 1.05-1~precise2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to replace dh-apparmor 2.7.102-0ubuntu3.7 (using
.../dh-apparmor_2.7.102-0ubuntu3.8_all.deb) ...
Unpacking replacement dh-apparmor ...
Preparing to replace osm2pgrouting 0.1-6 (using
.../osm2pgrouting_2.0.0-beta-ppa4_amd64.deb) ...
Unpacking replacement osm2pgrouting ...
Processing triggers for man-db ...
Processing triggers for ureadahead ...
ureadahead will be reprofiled on next reboot
Processing triggers for hicolor-icon-theme ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
View this message in context: http://pgrouting-users.974093.n3.nabble.com/pgrouting-users-OSM2pgRouting-failling-silently-tp4025288p4025293.html
Sent from the pgRouting-users mailing list archive at Nabble.com.
More information about the Pgrouting-users
