[pgrouting-users] Error compiling pgRouting 2.0 on Ubuntu 10.04
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Dec 4 12:14:02 PST 2013
Does this help you?
http://comments.gmane.org/gmane.comp.db.postgresql.general/146579
On 12/4/2013 11:43 AM, Luís de Sousa wrote:
> Hello everyone, I'm trying to compile pgRouting 2.0 on Ubuntu 10.04 (kernel
> 2.6.32-49-server). I have managed to install all the software required
> except for Sphinx and TexLive (I don't need the documentation at this
> stage). The result is what you see below. I'm using gcc 4.4.3, which is not
> that new, could it be the cause? What else then?
> Thanks.
> $ cmake ..
> -- PGROUTING_GIT_TAG: pgrouting-2.0.0
> -- PGROUTING_GIT_BUILD: 0
> -- PGROUTING_GIT_HASH: d6ed2cb
> -- PGROUTING_GIT_BRANCH: master
> -- PGROUTING_VERSION_REVISION_NAME: d6ed2cb master
> -- PGROUTING_VERSION_REVISION_HASH: d6ed2cb
> -- UNIX=1
> -- WIN32=
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/8.4/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/8.4/server
> -- POSTGRESQL_LIBRARIES: /usr/lib
> -- Boost version: 1.40.0
> -- Boost headers were found here: /usr/include
> -- POSTGRESQL_VERSION_STRING is PostgreSQL 8.4.17
> -- POSTGRESQL_VERSION is 8.4.17
> -- PGSQL_VERSION is 84
> -- Install directory for libraries is set to /usr/lib/postgresql/8.4/lib
> -- Contrib directory for SQL files is set to
> /usr/share/postgresql/8.4/contrib/pgrouting-2.0
> -- Found the following Boost libraries:
> -- thread
> -- CGAL_INCLUDE_DIR=/usr/include
> -- CGAL_LIBRARIES=/usr/lib/libCGAL.so
> -- BOOST_THREAD_LIBRARIES=/usr/lib/libboost_thread-mt.so
> -- GMP_LIBRARIES=/usr/lib/libgmp.so
> -- Found CGAL: /usr/include, /usr/lib/libCGAL.so,
> /usr/lib/libboost_thread-mt.so, /usr/lib/libgmp.so
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/desousa/pgrouting/build
> $ make
> Scanning dependencies of target trsp
> [ 2%] Building C object src/trsp/src/CMakeFiles/trsp.dir/trsp.c.o
> [ 5%] Building CXX object src/trsp/src/CMakeFiles/trsp.dir/trsp_core.cpp.o
> [ 8%] Building CXX object
> src/trsp/src/CMakeFiles/trsp.dir/GraphDefinition.cpp.o
> [ 8%] Built target trsp
> Scanning dependencies of target astar
> [ 11%] Building C object src/astar/src/CMakeFiles/astar.dir/astar.c.o
> [ 14%] Building CXX object
> src/astar/src/CMakeFiles/astar.dir/astar_boost_wrapper.cpp.o
> [ 14%] Built target astar
> Scanning dependencies of target dijkstra
> [ 17%] Building C object
> src/dijkstra/src/CMakeFiles/dijkstra.dir/dijkstra.c.o
> [ 20%] Building CXX object
> src/dijkstra/src/CMakeFiles/dijkstra.dir/boost_wrapper.cpp.o
> [ 20%] Built target dijkstra
> Scanning dependencies of target kdijkstra
> [ 22%] Building CXX object
> src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o
> [ 25%] Building C object
> src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_sp.c.o
> [ 25%] Built target kdijkstra
> Scanning dependencies of target apsp_johnson
> [ 28%] Building C object
> src/apsp_johnson/src/CMakeFiles/apsp_johnson.dir/apsp_johnson.c.o
> [ 31%] Building CXX object
> src/apsp_johnson/src/CMakeFiles/apsp_johnson.dir/apsp_johnson_boost_wrapper.cpp.o
> [ 31%] Built target apsp_johnson
> Scanning dependencies of target apsp_warshall
> [ 34%] Building C object
> src/apsp_warshall/src/CMakeFiles/apsp_warshall.dir/apsp.c.o
> [ 37%] Building CXX object
> src/apsp_warshall/src/CMakeFiles/apsp_warshall.dir/apsp_boost_wrapper.cpp.o
> [ 37%] Built target apsp_warshall
> Scanning dependencies of target routing
> Linking CXX shared library lib/librouting.so
> [ 37%] Built target routing
> Scanning dependencies of target bd_dijkstra
> [ 40%] Building C object
> src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/bdsp.c.o
> [ 42%] Building CXX object
> src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/bdsp_core.cpp.o
> [ 45%] Building CXX object
> src/bd_dijkstra/src/CMakeFiles/bd_dijkstra.dir/BiDirDijkstra.cpp.o
> [ 45%] Built target bd_dijkstra
> Scanning dependencies of target bd_astar
> [ 48%] Building C object
> src/bd_astar/src/CMakeFiles/bd_astar.dir/bdastar.c.o
> [ 51%] Building CXX object
> src/bd_astar/src/CMakeFiles/bd_astar.dir/MinHeap.cpp.o
> [ 54%] Building CXX object
> src/bd_astar/src/CMakeFiles/bd_astar.dir/bdastar_core.cpp.o
> [ 57%] Building CXX object
> src/bd_astar/src/CMakeFiles/bd_astar.dir/BiDirAStar.cpp.o
> [ 57%] Built target bd_astar
> Scanning dependencies of target routing_bd
> Linking CXX shared library lib/librouting_bd.so
> [ 57%] Built target routing_bd
> Scanning dependencies of target routing_tsp
> [ 60%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsp2.c.o
> [ 62%] Building C object src/tsp/src/CMakeFiles/routing_tsp.dir/tsplib.c.o
> Linking C shared library ../../../lib/librouting_tsp.so
> [ 62%] Built target routing_tsp
> Scanning dependencies of target routing_ksp
> [ 65%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/BaseGraph.cpp.o
> [ 68%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/BasePath.cpp.o
> [ 71%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/DijkstraShortestPathAlg.cpp.o
> [ 74%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/Graph.cpp.o
> [ 77%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/HeaderTest.cpp.o
> [ 80%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/YenTopKShortestPathsAlg.cpp.o
> [ 82%] Building C object src/ksp/src/CMakeFiles/routing_ksp.dir/ksp.c.o
> [ 85%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/KSPDriver.cpp.o
> [ 88%] Building CXX object
> src/ksp/src/CMakeFiles/routing_ksp.dir/KSPGraph.cpp.o
> In file included from
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:24,
> from /usr/include/postgresql/8.4/server/executor/spi.h:16,
> from /home/desousa/pgrouting/src/ksp/src/KSPGraph.cpp:16:
> /usr/include/postgresql/8.4/server/nodes/primnodes.h:1155: error: expected
> unqualified-id before ‘using’
> ‘;’ before ‘using’
> In file included from /usr/include/postgresql/8.4/server/executor/spi.h:16,
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:176: error: expected
> unqualified-id before ‘typeid’
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:259: error: expected
> unqualified-id before ‘typename’
> ‘;’ before ‘typename’
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:459: error: expected
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:556: error: expected
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:1170: error: expected
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:1674: error: expected
> /usr/include/postgresql/8.4/server/nodes/parsenodes.h:2088: error: expected
> make[2]: *** [src/ksp/src/CMakeFiles/routing_ksp.dir/KSPGraph.cpp.o] Error 1
> make[1]: *** [src/ksp/src/CMakeFiles/routing_ksp.dir/all] Error 2
> make: *** [all] Error 2
> View this message in context: http://pgrouting-users.974093.n3.nabble.com/Error-compiling-pgRouting-2-0-on-Ubuntu-10-04-tp4025407.html
> Sent from the pgRouting-users mailing list archive at Nabble.com.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
