[pgrouting-users] Problem when running osm2pgrouting
maruf rahman
maruf.csdu at gmail.com
Thu Feb 21 08:59:16 PST 2013
Hi Daniel,
Everything is fine until adding pgrouting core functions. When i try to
execute these two command
*sudo -u $USER_NAME psql --quiet -f
$PGROUTING_FOLDER/routing_core_wrappers.sql $OSM_DB
sudo -u $USER_NAME psql --quiet -f $PGROUTING_FOLDER/routing_topology.sql
$OSM_DB*
it generates some error. Please see the output<http://paste.ubuntu.com/1700119/>
What is the solution?
Thanks
Maruf
On Thu, Feb 21, 2013 at 10:04 PM, Daniel Kastl <daniel at georepublic.de>wrote:
> Hi Maruf,
> You can't run this script just as it is, because it uses the same sample
> data, that has been downloaded by the OSM install script before (different
> script).
> Also OSGeo Live has a an admin user named "user", so this might not work
> for you either.
> So I would recommend you to just pick the commands you need and change
> them where necessary. You can use your own OSM data for example, but you
> probably need to adjust the path then.
> Daniel
> On Fri, Feb 22, 2013 at 12:59 AM, maruf rahman <maruf.csdu at gmail.com>wrote:
>> Hi Daniel,
>> I have run the script using *bash ./install_pgrouting.sh
>> Please check a part of output here <http://paste.ubuntu.com/1699747/>.
>> Its missing sample data and there are some database issue.
>> Thanks
>> Maruf
>> On Thu, Feb 21, 2013 at 9:46 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>> Hi Maruf,
>>> Looking at the Gist, there is no need anymore to compile PostGIS 2.0,
>>> because it already has packages in the UbuntuGIS unstable repository.
>>> It furthermore installs pgRouting as packages as well as osm2pgrouting,
>>> which is good.
>>> I don't know, why it doesn't work in your case and why you're missing
>>> tables. Well, there is a t least one issue with osm2pgrouting when using
>>> PostGIS 2.0, which requires some hack. And you may have to load
>>> "legacy.sql".
>>> Just a few days ago I updated the pgRouting installer for the new OSGeo
>>> Live DVD and that it is working has been confirmed by several people:
>>> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/branches/osgeolive_6_5/bin/install_pgrouting.sh
>>> So maybe this OSGeo Live install script is more up-to-date. Because
>>> pgRouting/osm2pgrouting still may have issues with PostGIS 2.0, you either
>>> need to fix some wrapper SQL functions or load legacy.sql to your database
>>> (see line #97).
>>> And the hack for osm2pgrouting is from line #138.
>>> Daniel
>>> On Fri, Feb 22, 2013 at 12:31 AM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>>> OS: Ubuntu 12.04
>>>> I have installed pgrouting dependencies using this url
>>>> https://gist.github.com/djq/2846196
>>>> and pgrouting using this tutorial
>>>> http://pgrouting.org/docs/1.x/install.html
>>>> and didn't use LiveDVD.
>>>> Please let me know if any more info is needed.
>>>> Maruf
>>>> On Thu, Feb 21, 2013 at 8:59 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>>>> Hi Maruf,
>>>>> Can you provide more information?
>>>>> Like which OS you use, how you installed pgRouting, etc..
>>>>> Do you use the OSGeo LiveDVD?
>>>>> Daniel
>>>>> On Thu, Feb 21, 2013 at 11:38 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>>>>> Hi
>>>>>> I am trying to use pgrouting following this tutorial<http://workshop.pgrouting.org/index.html>.
>>>>>> Currently I am in section 4.2<http://workshop.pgrouting.org/chapters/osm2pgrouting.html>.
>>>>>> However when I try to execute the command of section 4.2, it only creates 3
>>>>>> tables name *classes, nodes* and *types*. But the document says, it
>>>>>> should create 8 tables.
>>>>>> Where is the problem? How can I solve this?
>>>>>> Thanks
>>>>>> Maruf
>>>>>> _______________________________________________
>>>>>> Pgrouting-users mailing list
>>>>>> Pgrouting-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>>> Georepublic UG & Georepublic Japan
>>>>> eMail: daniel.kastl at georepublic.de
>>>>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130221/2b0b82cf/attachment-0001.html>
More information about the Pgrouting-users
