[pgrouting-users] select multiple shortest paths from one to several points
Nate Wessel bike756 at gmail.com
Thu Jul 18 10:45:19 PDT 2013
I'm looking to select a number of shortest paths from one point to each
of a set of points. For example, I would like to generate paths from my
house to every coffee shop in the metro area.
Conceptually, it seems like this should be a simple problem, but I'm
running into issues when I try to construct a query to actually do it. I
managed to get as far as getting a nearest-network-node ID for each of
my coffee shops into a table by themselves.
 From that point, I get a little lost. As far as I can tell, I have
three tables to join together somehow: The network edges table, the
table with the destination node IDs, and the table that results from a
shortest path query. It's simple enough to join the network edge table
geometry to the result of a single path query. But how do I pass a
variable from my node IDs table to the end-point parameter of a
shortest-path function?
When I tried something like:
SELECT
FROM destination_nodes, shortest_path(..., network_nodes.id ,...)
JOIN network_edges ON ....
I get an error saying I can't pass a variable from the same query level
to the function.
Can someone please help me understand how I need to structure this query
to get the geometry of the paths associated with information from my
destination_nodes table?
Much thanks,
Nate
More information about the Pgrouting-users mailing list
