[pgrouting-users] suspected bug in TSP distance matrix pgRouting RC1 released[SOLUTION]
sanak
geosanak at gmail.com
Fri Jul 19 07:00:41 PDT 2013
Hi Dave,
Yes, it is also necessary.
https://github.com/sanak/pgrouting4w/commit/fa8c5ff559344653a464f2c3416de0ef8c4ce393
By the way, in my environment(currently use MacOSX),
your 2nd result was as follows, and it is not same as 1st one.
pgrouting-workshop=# SELECT seq, id FROM
pgr_tsp('{{0,0.1,0.3,0.3},{0.1,0,0.2,0.2},{0.3,0.2,0,0.2},{0.3,0.2,0.2,0}}'::float8[],1);
seq | id
0 | 1
1 | 0
2 | 3
3 | 2
(4 rows)
In your environment, is there no problem?
Regards,
2013/7/19 Dave Potts <dave.potts at pinan.co.uk>
> On 19/07/13 15:08, Dave Potts wrote:
> I have found the problem, in the function int findEulerianPath(TSP *tsp)
> in the file src/tsp/src/tsplib.c
> the code says something like
> int d,i,j,k,l,a
> The varible d is used to compare against a variable of type DTYPE, with
> the result that there seems to be an underflow/overflow issue
> so the code needs to be changed to
> int *mst, *arc;
> DTYPE d;
> int i, j, k, l, a;
> int n, *iorder, *jorder;
> having done, I now get the expected result.
> Dave.
> On 19/07/13 13:02, sanak wrote:
> Hi Sanak
> Thanks for your help
> I had the float version in my source base I changed it to a double, I have
> done a make clean, install restarted the service, still have the same
> problem :-(
> Dave
> Hi Dave, Stephen,
> I encountered the same issue(
> https://github.com/pgRouting/pgrouting/issues/159 ),
> so, I sent the pull request(
> https://github.com/pgRouting/pgrouting/pull/160 ).
> > Stephen
> Could you check my pull request?
> Thanks,
>> I have been trying to do some work which requires the tsp, some of my
>> values have values of 0.1 in the dataset, I keep getting odd results.
>> So I tried a well known example from the pgr _tsp distance page and it
>> work as expected.
>> I then repeated the same example but reduced all of the distance by a
>> factor off 10 and got an error. Unless I have make a mistake in my
>> understanding of the manual page, I think we might a problem where
>> -- version used
>> select pgr_version();
>> pgr_version
>> (2.0.0-dev,v2.0.0-rc1,0,bf13fd7,develop,1.48.0)
>> -- Use a example get a result set
>> SELECT seq, id FROM
>> pgr_tsp('{{0,1,3,3},{1,0,2,2},{3,2,0,2},{3,2,2,0}}'::float8[],1);
>> seq | id
>> 0 | 1
>> 1 | 2
>> 2 | 3
>> 3 | 0
>> (4 rows)
>> -- repeat for reduce everything by scale factor of 10 ie 1.0 becomes
>> 0.1 etc
>> SELECT seq, id FROM
>> ERROR: Error TSP fail to findEulerianPath, check your distance matrix is
>> valid.
>> As far as I understand it my matrix has 0's on the leading diangonal and
>> [a,b] == [b,a]
>> Dave.
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Ko Nagase (sanak)
> Georepublic Japan
> mail: geosanak at gmail.com
> nagase at georepublic.co.jp
> Pgrouting-users mailing listPgrouting-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-users
Ko Nagase (sanak)
Georepublic Japan
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130719/00511d9f/attachment.html>
More information about the Pgrouting-users
