[pgrouting-users] Distance matrix using road network
Laura Kauria
lacation at gmail.com
Wed Jul 24 22:22:51 PDT 2013
Thanks, Steve! I need to start first with something easier, since I see
lots of gaps with my skills and this tool(/general pgrouting). I try to
figure out it first in grass and if it goes fine, then pgrouting. Cheers,
Laura
2013/7/24 Stephen Woodbridge <woodbri at swoodbridge.com>
> On 7/24/2013 2:19 PM, Laura Kauria wrote:
>> Hi all,
>> I'm new with pgrouting/postgresql and I would need some detailed
>> instructions making distance matrix using road network. Can you lead me
>> to a good source or give some instructions here to get started?
>> Thanks in advance! I have mac and I'd like to use pgrouting via QGIS or
>> grass.
> Hi Laura,
> I will outline the process below, but you should read the docs for the
> details on how to do the steps:
> Say you have ten locations the you want to build a distance matrix for:
> 1. map you locations to the nearest edge nearest end node
> 2. for each node call pgr_kdijkstra() with the node as source and the
> remainder of nodes as targets.
> 3. place the values in real8[][] array
> 4. adjust the array to be symmetric ie: a[i,j] == a[j,i] (we only support
> symmetric TSP
> 5. call pgr_tsp(a, start_id [, end_id])
> I have no idea how you would do this from QGIS or grass.
> Hope this helps,
> -Steve
> ______________________________**_________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130725/388a62fe/attachment.html>
More information about the Pgrouting-users
