[pgrouting-users] PgRouting fails to compile on Ubuntu 13.04
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 29 07:39:43 PDT 2013
Oh and the version of Boost might be a problem. I recommend using 1.42
which is what I use here into we sort out issues using the new versions.
-Steve
On 6/29/2013 10:07 AM, Nate Wessel wrote:
> Howdy all,
> I've spent the last three days trying to install PgRouting on my Xubuntu
> 13.04 machine. I've got a deadline coming up for a big cartography
> project and this is driving me up a wall! I was able to install the
> program quite easily through the PPA before I upgraded from Ubuntu
> 12.04. I tried adding the PPA again, but I get a 404, I guess because
> there's nothing there for Raring yet.
> I've tried following every set of installation instructions on the web
> to no avail.
> I tried compiling both the stable and unstable releases from source but
> things keep failing. At first, cmake failed to find my postgresql
> installation. After poking around a bit and adding an extra directories
> to cmake/FindPostgreSQL.cmake, the errors went away and it looked like
> cmake had run successfully:
> nate at desktop:/usr/local/src/pgrouting$ cmake .
> -- PGROUTING_GIT_TAG: v2.0.0-alpha
> -- PGROUTING_GIT_BUILD: 97
> -- PGROUTING_GIT_HASH: 9193863
> -- PGROUTING_GIT_BRANCH: develop
> -- PGROUTING_VERSION_REVISION_NAME: 9193863 develop
> -- PGROUTING_VERSION_REVISION_HASH: 9193863
> -- UNIX=1
> -- WIN32=
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql
> -- POSTGRESQL_LIBRARIES: /usr/lib
> -- Boost version: 1.49.0
> Boost headers were found here: /usr/include
> -- POSTGRESQL_VERSION_STRING is PostgreSQL 9.1.9
> -- POSTGRESQL_VERSION is 9.1.9
> -- Install directory for libraries is set to /usr/lib/postgresql/9.1/lib
> -- Contrib directory for SQL files is set to
> /usr/share/postgresql/9.1/contrib/pgrouting-2.0
> -- Extension directory for SQL files is set to
> /usr/share/postgresql/9.1/extension
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /usr/local/src/pgrouting
> When I run make however, it quickly fails to find some includes:
> nate at desktop:/usr/local/src/pgrouting$ make
> Scanning dependencies of target trsp
> [  3%] Building C object src/trsp/src/CMakeFiles/trsp.dir/trsp.c.o
> /usr/local/src/pgrouting/src/trsp/src/trsp.c:2:26: fatal error:
> executor/spi.h: No such file or directory
> compilation terminated.
> make[2]: *** [src/trsp/src/CMakeFiles/trsp.dir/trsp.c.o] Error 1
> make[1]: *** [src/trsp/src/CMakeFiles/trsp.dir/all] Error 2
> make: *** [all] Error 2
> I'm getting a little desparate! Can anyone help me with this? I'd give
> anything to just have the GUI package manager take care of all this for me.
> I have no idea what I'm doing trying to compile from source. I can
> follow the instructions from the README.md file, but not after they fail
> on the first step ;-)
> Thanks,
> Nate
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
