[pgrouting-users] Pgrouting-users Digest, Vol 57, Issue 12
    Nate Wessel
    bike756 at gmail.com
    Sat Jun 29 15:18:24 PDT 2013
Steve: You're amazing! I installed "postgresql-server-dev-all" after a
search for "postgresql-dev" in Synaptic and it then installed perfectly.
THANKS!
Nate
On 06/29/2013 03:00 PM, pgrouting-users-request at lists.osgeo.org wrote:
> Send Pgrouting-users mailing list submissions to
> 	pgrouting-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	pgrouting-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Pgrouting-users digest..."
> Today's Topics:
>     1. Re: TSP Euclidean distance function (Stephen Woodbridge)
>     2. PgRouting fails to compile on Ubuntu 13.04 (Nate Wessel)
>     3. Re: PgRouting fails to compile on Ubuntu 13.04
>     4. Re: PgRouting fails to compile on Ubuntu 13.04
> Message: 1
> Date: Fri, 28 Jun 2013 21:03:00 -0400
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> To: pgrouting-users at lists.osgeo.org
> Subject: Re: [pgrouting-users] TSP Euclidean distance function
> Message-ID: <51CE3244.9090505 at swoodbridge.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Here is an interesting way deal with this problem:
> create or replace function pgr_makeDistanceMatrix(sqlin text, OUT
> dmatrix double precision[], OUT ids integer[])
>     as
> $body$
> declare
>       sql text;
>       r record;
> begin
>       dmatrix := array[]::double precision[];
>       ids := array[]::integer[];
>       sql := 'with nodes as (' || sqlin || ')
>           select i, array_agg(dist) as arow from (
>               select a.id as i, b.id as j, st_distance(st_makepoint(a.x,
> a.y), st_makepoint(b.x, b.y)) as dist
>                 from nodes a, nodes b
>                order by a.id, b.id
>              ) as foo group by i order by i';
>       for r in execute sql loop
>           dmatrix := array_cat(dmatrix, array[r.arow]);
>           ids := ids || array[r.i];
>       end loop;
> end;
> $body$
> language plpgsql stable cost 10;
> with dm  as (
>       select * from pgr_makeDistanceMatrix(
>           'select source_id as id, x, y
>              from tsp_00
>             where source_id in (1,7,16,3,5)')
>     ids as (
>       select (row_number() over (order by id asc))-1 as rnum, id
>         from (
>               select unnest(ids) as id
>                 from dm
>               ) foo
> select a.seq, b.rnum, b.id, d.dmatrix[a.seq+1][b.rnum+1] as dist
>     from pgr_tsp(
>                  (select dmatrix from dm),
>                  (select rnum from ids where id=7)::integer
>          ) a,
>          ids b,
>          dm d
>    where a.id=b.rnum;
> i; j; id; cost
> 0; 3; 7; 6
> 1; 0; 1; 2.23606797749979
> 2; 1; 3; 3
> 3; 2; 5; 4.47213595499958
> 4; 4; 16; 0                <<-- this line seems to be bad see below
> Since it took me all afternoon and evening to figure this out I will
> leave that as an exercise for the reader, but feel free to ask questions.
> I think the whole second query can be wrapped in a stored procedure
> where it takes sql string the gets dropped into the dm CTE and returns
> the results.
> I think there is a bug in my logic somewhere because I always seem to
> get back one row there the seq=rnum and the cost is zero so this not is
> not linked to the path.
> But my brain is too fried to make sense of this anymore tonight.
> Thoughts,
>     -Steve
> On 6/28/2013 10:17 AM, Stephen Woodbridge wrote:
>> Hi All,
>> I'm trying to understand how the old TSP code was supposed to work, as
>> it is not making any sense to me. So the signature is:
>> select * from pgr_tsp(sql text, ids text, start_id integer, end_id
>> integer);
>> sql - sql that selects some number of point that have id, x, and y, ie:
>> 'select id, x, y from table'
>> ids - is a comma separated list of ids, :ie: '3,27,44,6'
>> start_id - must be one of the ids in the ids list
>> end_id - [optional] will be the end of the path if passed in, otherwise
>> assumes a loop. must be in ids
>> Currently 'sql' can select an arbitrary list of nodes greater than the
>> list of ids. This does not make any sense to me and the code behaves
>> badly in this case. For example if you select 100 points in the sql and
>> only have 5 in the ids list what does this mean? Why is the ids list
>> separate from the sql?
>> Currently the code only works cleanly if the the sql returns exactly the
>> list of ids. ie:
>>     'select id, x, y from mytable where id in (3,27,44,6)',
>>    '3,27,44,6',
>>    3, -1);
>> This seems redundant and messy at best.
>> Can anyone clear up what was supposed to happen in the old version?
>> I'm temped to just through out the old code and rewrite this as a
>> wrapper that computes a distance matrix and calls the matrix function,
>> or something like that.
>> Thoughts, use cases?
>> -Steve
>> Pgrouting-users at lists.osgeo.org
> Message: 2
> Date: Sat, 29 Jun 2013 10:07:21 -0400
> From: Nate Wessel <bike756 at gmail.com>
> Subject: [pgrouting-users] PgRouting fails to compile on Ubuntu 13.04
> Message-ID: <51CEEA19.40407 at gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Howdy all,
> I've spent the last three days trying to install PgRouting on my Xubuntu
> 13.04 machine. I've got a deadline coming up for a big cartography
> project and this is driving me up a wall! I was able to install the
> program quite easily through the PPA before I upgraded from Ubuntu
> 12.04. I tried adding the PPA again, but I get a 404, I guess because
> there's nothing there for Raring yet.
> I've tried following every set of installation instructions on the web
> to no avail.
> I tried compiling both the stable and unstable releases from source but
> things keep failing. At first, cmake failed to find my postgresql
> installation. After poking around a bit and adding an extra directories
> to cmake/FindPostgreSQL.cmake, the errors went away and it looked like
> cmake had run successfully:
> nate at desktop:/usr/local/src/pgrouting$ cmake .
> -- PGROUTING_GIT_TAG: v2.0.0-alpha
> -- PGROUTING_GIT_BUILD: 97
> -- PGROUTING_GIT_HASH: 9193863
> -- PGROUTING_GIT_BRANCH: develop
> -- PGROUTING_VERSION_REVISION_NAME: 9193863 develop
> -- PGROUTING_VERSION_REVISION_HASH: 9193863
> -- UNIX=1
> -- WIN32=
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql
> -- POSTGRESQL_LIBRARIES: /usr/lib
> -- Boost version: 1.49.0
> Boost headers were found here: /usr/include
> -- POSTGRESQL_VERSION_STRING is PostgreSQL 9.1.9
> -- POSTGRESQL_VERSION is 9.1.9
> -- Install directory for libraries is set to /usr/lib/postgresql/9.1/lib
> -- Contrib directory for SQL files is set to
> /usr/share/postgresql/9.1/contrib/pgrouting-2.0
> -- Extension directory for SQL files is set to
> /usr/share/postgresql/9.1/extension
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /usr/local/src/pgrouting
> When I run make however, it quickly fails to find some includes:
> nate at desktop:/usr/local/src/pgrouting$ make
> Scanning dependencies of target trsp
> [  3%] Building C object src/trsp/src/CMakeFiles/trsp.dir/trsp.c.o
> /usr/local/src/pgrouting/src/trsp/src/trsp.c:2:26: fatal error:
> executor/spi.h: No such file or directory
> compilation terminated.
> make[2]: *** [src/trsp/src/CMakeFiles/trsp.dir/trsp.c.o] Error 1
> make[1]: *** [src/trsp/src/CMakeFiles/trsp.dir/all] Error 2
> make: *** [all] Error 2
> I'm getting a little desparate! Can anyone help me with this? I'd give
> anything to just have the GUI package manager take care of all this for me.
> I have no idea what I'm doing trying to compile from source. I can
> follow the instructions from the README.md file, but not after they fail
> on the first step ;-)
> Thanks,
> Nate
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130629/60e14879/attachment-0001.html>
> Message: 3
> Date: Sat, 29 Jun 2013 10:37:32 -0400
> Subject: Re: [pgrouting-users] PgRouting fails to compile on Ubuntu
> 	13.04
> Message-ID: <51CEF12C.6090105 at swoodbridge.com>
> Nate,
> It looks like you need to install the various *-dev packages for thins
> like postgresql, boost, cgal, etc.
> -Steve
> On 6/29/2013 10:07 AM, Nate Wessel wrote:
>> Howdy all,
>> to no avail.
>> -- UNIX=1
>> -- WIN32=
>> -- Configuring done
>> -- Generating done
>> Thanks,
>> Nate
> Message: 4
> Date: Sat, 29 Jun 2013 10:39:43 -0400
> 	13.04
> Message-ID: <51CEF1AF.1020500 at swoodbridge.com>
> Oh and the version of Boost might be a problem. I recommend using 1.42
> which is what I use here into we sort out issues using the new versions.
> -Steve
>> Howdy all,
>> to no avail.
>> -- UNIX=1
>> -- WIN32=
>> -- Configuring done
>> -- Generating done
>> Thanks,
>> Nate
> End of Pgrouting-users Digest, Vol 57, Issue 12
More information about the Pgrouting-users
