[pgrouting-users] Syntax error in sampledata_notopo.sql
maruf rahman maruf.csdu at gmail.com
Sat Mar 9 12:38:23 PST 2013
Hi Daniel
I have reinstalled everything and started from scratch. However when i
execute this command *
psql -d routing -f /usr/share/postgresql/9.1/contrib/postgis-2.0/postgis.sql
it generates this error <http://paste.ubuntu.com/5600036/>.
How can I solve this?
Thanks
Maruf
On Sat, Mar 9, 2013 at 9:32 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Maruf,
> In your first email you wrote, that you created a database first. But the
> database creation is actually part of SQL dump file already.
> You can also just login to some other database and then run "\i
> path/to/sampledata_notopo.sql"
> Inside this file it creates the database like this:
> CREATE DATABASE "pgrouting-workshop" WITH TEMPLATE = template_routing
> ENCODING = 'UTF8' LC_COLLATE = 'en_US.UTF-8' LC_CTYPE = 'en_US.UTF-8';
> So it is looking for a "template_routing" template database, that was
> mentioned in a previous chapter.
> The errors you posted you need to debug from top. So first it complains
> about already existing database and second about missing "geometry" things.
> When using the template database it should work.
> Daniel
> On Sun, Mar 10, 2013 at 12:22 AM, maruf rahman <maruf.csdu at gmail.com>wrote:
>> Here is the original sampledata_notopo.sql file.
>> https://docs.google.com/file/d/0B3djwV2dbCYZVV9QVjg3TngzUzg/edit?usp=sharing
>> On Sat, Mar 9, 2013 at 9:18 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>> Hi
>>> The problem still occurs. Here is the output<http://paste.ubuntu.com/5599146/>
>>> Previously i replaced all '\N', so it wasn't in error list. Now I have
>>> run the command in original file.
>>> Thanks
>>> Maruf
>>> On Sat, Mar 9, 2013 at 8:46 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>>> Hi Maruf,
>>>> Could be that this version of the workshop is outdated as it's the one
>>>> from FOSS4G 2010.
>>>> Can you try the workshop FOSS4G 2011 instead?
>>>> The most up-to-date content is always the online version:
>>>> http://workshop.pgrouting.org/
>>>> Daniel
>>>> On Sat, Mar 9, 2013 at 11:28 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>>>> Hi
>>>>> I am trying to install and use pgrouting using the attached document.
>>>>> Currently I am in step 5.1(Load network data). It says to create a database
>>>>> and load data in it using the following two commands.
>>>>> *createdb -U postgres pgrouting-workshop
>>>>> psql -U postgres -d pgrouting-workshop \
>>>>> -f ~/Desktop/pgrouting-workshop/data/sampledata_notopo.sql*
>>>>> The first one goes well. When I execute the second command I get some
>>>>> errors. Please check here <http://paste.ubuntu.com/5598943/>.
>>>>> Here<https://docs.google.com/file/d/0B3djwV2dbCYZMk1kZS1mQmdYVTg/edit?usp=sharing>is the sampledata_notopo.sql file.
>>>>> How can I solve this problem?
>>>>> Thanks
>>>>> Maruf
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130310/b59c5f18/attachment.html>
More information about the Pgrouting-users mailing list
