[pgrouting-users] Syntax error in sampledata_notopo.sql
maruf rahman
maruf.csdu at gmail.com
Sun Mar 10 09:41:28 PDT 2013
Hi Daniel,
Now I am at section
6.1<http://workshop.pgrouting.org/chapters/shortest_path.html#dijkstra>
What are the actual parameters of this query?
*shortest_path( sql text,
source_id integer,
target_id integer,
directed boolean,
has_reverse_cost boolean )*
Could you please give an original function call, which will work?
Additionally where should I run this? in psql query interface or in normal
console?
Maruf
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130310/c88b45db/attachment.html>
More information about the Pgrouting-users
