[pgrouting-users] ERROR: function startpoint(geometry) does not exist
Jelmer Baas
baas at speerit.nl
Tue Mar 12 12:20:41 PDT 2013
I tried this a while back, and found that it's not all that much work to re-write the functions to support Postgis 2.0: the only requirement was adding 'ST_' to all most calls.
Regards,
Jelmer
-----Original Message-----
From: pgrouting-users-bounces at lists.osgeo.org [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen V. Mather
Sent: Tuesday, March 12, 2013 19:32
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] ERROR: function startpoint(geometry) does not exist
To echo Stephen, in my experience, running the legacy.sql file against your database eliminates all the compatibility issues.
Best,
Steve
Stephen V. Mather
GIS Manager
(216) 635-3243 (Work)
clevelandmetroparks.com
________________________________________
From: pgrouting-users-bounces at lists.osgeo.org [pgrouting-users-bounces at lists.osgeo.org] on behalf of Stephen Woodbridge [woodbri at swoodbridge.com]
Sent: Tuesday, March 12, 2013 2:13 PM
To: pgrouting-users at lists.osgeo.org
Right you are using postgis 2.0 and the tutorial was written for postgis
1.5.x
You might solve some of these problems but installing legacy.sql.
google: postgis 2.0 legacy.sql
-steve
On 3/12/2013 1:56 PM, maruf rahman wrote:
> Hi
> I am in section 5.2 of thistutorial <http://workshop.pgrouting.org/chapters/topology.html>.
> When i run this command
> SELECT*//* assign_vertex_id('ways', 0.00001, 'the_geom', 'gid'*//*);*/
> i get the following error/*
> pgrouting-workshop=# SELECT assign_vertex_id('ways', 0.00001, 'the_geom', 'gid');
> NOTICE: CREATE TABLE will create implicit sequence "vertices_tmp_id_seq" for serial column "vertices_tmp.id <http://vertices_tmp.id>"
> CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
> PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
> LINE 1: SELECT gid AS id, StartPoint(the_geom) AS source, EndPoint(t...
> HINT: No function matches the given name and argument types. You might need to add explicit type casts.
> QUERY: SELECT gid AS id, StartPoint(the_geom) AS source, EndPoint(the_geom) as target FROM ways
> CONTEXT: PL/pgSQL function "assign_vertex_id" line 27 at FOR over EXECUTE statement
> Seems like I am missing the startpoint(geometry) function.
> How can I fix this?
> Thanks
> Maruf
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
