[pgrouting-users] PgRouting sew-devel-2_0 : topology problem
Frédéric Bonifas fredericbonifas at gmail.com
Mon Mar 18 09:31:50 PDT 2013
Thank you for these answers,
* Running legacy.sql did help : the "ways" table is now filled.
psql -d routing -f /usr/share/postgresql/9.1/contrib/postgis-2.0/legacy.sql
* For assign_vertex_id(), I thought that it was already run by
osm2pgrouting as it writes :
create topology
NOTICE:  CREATE TABLE will create implicit sequence
"vertices_tmp_id_seq" for serial column "vertices_tmp.id"
CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
size of streets: 41
size of splitted ways : 469
finished
In the osm2pgrouting source :
https://github.com/pgRouting/osm2pgrouting/blob/master/src/Export2DB.cpp#L372
But the vertices_tmp table remains empty. When running manually SELECT
assign_vertex_id('ways', 0.00001, 'the_geom', 'gid'); I get this :
ERROR:  query string argument of EXECUTE is null
CONTEXT:  PL/pgSQL function "assign_vertex_id" line 33 at EXECUTE statement
My "ways" table is in MultiLineString geometry type. Could the problem
come from that ?
Frédéric Bonifas
2013/3/18 Stephen Woodbridge <woodbri at swoodbridge.com>:
> On 3/18/2013 10:48 AM, Frédéric Bonifas wrote:
>> Hi,
>> I have built PgRouting from the sew-devel-2_0 branch. I am using
>> Postgis 2.0 and PostgreSql 9.1.8
>> I have created a database "routing" and created the postgis and
>> pgrouting extensions on it :
>> createdb routing
>> createlang plpgsql routing
> You can use "CREATE EXTENSION plpgsql" but I'm not sure it is even needed.
>> psql -d routing -c "CREATE EXTENSION postgis;"
>> psql -d routing -c "CREATE EXTENSION pgrouting;"
>> I did not run the following lines because I assume that "CREATE
>> EXTENSION pgrouting;" does that but I may be wrong. Anyway, the
>> /usr/share/postlbs/ directory is empty.
>> psql -d routing -f /usr/share/postlbs/routing_core.sql
>> psql -d routing -f /usr/share/postlbs/routing_core_wrappers.sql
>> psql -d routing -f /usr/share/postlbs/routing_topology.sql
> Right when you install an extension it loads all the files as part of the
> extension. And I do not install files in /usr/share/postlbs The extension
> installs share/postgresql/extension/pgrouting--1.0.7.sql which contains all
> the SQL concatenated into one file.
> One problem with the current setup is that tsp and dd are optional and as a
> result probably need to be broken out into separate extensions, but that
> should not be a problem for now.
>> Then I run osm2pgrouting, from the georepublic ppa.
>> osm2pgrouting -file "data.osm" -conf
>> "/usr/share/osm2pgrouting/mapconfig.xml" -host localhost -dbname
>> routing -user postgres -clean
>> osm2pgrouting seems the end coorectly as I got :
>> size of streets: 41
>> finished
>> But while the "nodes" table is correctly filled, the "ways" and
>> "vertices_tmp" tables remain empty. I suspect this might be related to
>> routing_core.sql, routing_core_wrappers.sql and routing_topology.sql
>> that I did not run.
>> Does someone know what I am doing wrong ?
> A couple of thoughts here:
> 1. you have to run the topology command assign_vertex_id(), which I have
> never used as I wrote my own a long time ago.
> 2. You might (most likely) will need to load legacy.sql from postgis until I
> have had a chance to review, update and test all the sql code for
> compatibility with postgis 2.x
> Thank you for stepping on on the bleed edge and testing this. I look forward
> to here about your success and failures. Hopefully more success than
> failures :)
> -Steve
>> Thanks in advance
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Frédéric Bonifas
+33672652807 skype:fredericbonifas
More information about the Pgrouting-users mailing list
