[pgrouting-users] PgRouting sew-devel-2_0 : topology problem
Frédéric Bonifas fredericbonifas at gmail.com
Mon Mar 18 16:10:46 PDT 2013
I just built osm2pgrouting from the source and it works now. It seems
like the geom type is already LINESTRING there :
https://github.com/pgRouting/osm2pgrouting/blob/master/src/Export2DB.cpp#L84
Thanks again for all the advices
Frédéric Bonifas
2013/3/18 Daniel Kastl <daniel at georepublic.de>:
>> In the osm2pgrouting source :
>> https://github.com/pgRouting/osm2pgrouting/blob/master/src/Export2DB.cpp#L372
>> But the vertices_tmp table remains empty. When running manually SELECT
>> assign_vertex_id('ways', 0.00001, 'the_geom', 'gid'); I get this :
>> NOTICE:  CREATE TABLE will create implicit sequence
>> "vertices_tmp_id_seq" for serial column "vertices_tmp.id"
>> CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"
>> PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
>> ERROR:  query string argument of EXECUTE is null
>> CONTEXT:  PL/pgSQL function "assign_vertex_id" line 33 at EXECUTE
>> statement
>> My "ways" table is in MultiLineString geometry type. Could the problem
>> come from that ?
> Yes, osm2pgrouting creates geometries as "MULTILINESTRING" which is not
> working anymore with functions like "ST_StartPoint" and ST_EndPoint" in
> PostGIS 2.0.
> Legacy.sql doesn't seem to help here.
> I found out that source and target column remain empty therefor. Best would
> be to change osm2pgrouting and recompile.
> In case you use the Ubuntu package and don't want to compile, you can alter
> the geometry type to LINESTRING (I don't think there is any MULTILINESTRING
> consisting of two lines created) and run assign_vertex_id manually once
> more.
> Daniel
>> Frédéric Bonifas
>> 2013/3/18 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> > On 3/18/2013 10:48 AM, Frédéric Bonifas wrote:
>> >> Hi,
>> >> I have built PgRouting from the sew-devel-2_0 branch. I am using
>> >> Postgis 2.0 and PostgreSql 9.1.8
>> >> I have created a database "routing" and created the postgis and
>> >> pgrouting extensions on it :
>> >> createdb routing
>> >> createlang plpgsql routing
>> > You can use "CREATE EXTENSION plpgsql" but I'm not sure it is even
>> > needed.
>> >> psql -d routing -c "CREATE EXTENSION postgis;"
>> >> psql -d routing -c "CREATE EXTENSION pgrouting;"
>> >> I did not run the following lines because I assume that "CREATE
>> >> EXTENSION pgrouting;" does that but I may be wrong. Anyway, the
>> >> /usr/share/postlbs/ directory is empty.
>> >> psql -d routing -f /usr/share/postlbs/routing_core.sql
>> >> psql -d routing -f /usr/share/postlbs/routing_core_wrappers.sql
>> >> psql -d routing -f /usr/share/postlbs/routing_topology.sql
>> > Right when you install an extension it loads all the files as part of
>> > the
>> > extension. And I do not install files in /usr/share/postlbs The
>> > extension
>> > installs share/postgresql/extension/pgrouting--1.0.7.sql which contains
>> > all
>> > the SQL concatenated into one file.
>> > One problem with the current setup is that tsp and dd are optional and
>> > as a
>> > result probably need to be broken out into separate extensions, but that
>> > should not be a problem for now.
>> >> Then I run osm2pgrouting, from the georepublic ppa.
>> >> osm2pgrouting -file "data.osm" -conf
>> >> "/usr/share/osm2pgrouting/mapconfig.xml" -host localhost -dbname
>> >> routing -user postgres -clean
>> >> osm2pgrouting seems the end coorectly as I got :
>> >> size of streets: 41
>> >> size of splitted ways : 469
>> >> finished
>> >> But while the "nodes" table is correctly filled, the "ways" and
>> >> "vertices_tmp" tables remain empty. I suspect this might be related to
>> >> routing_core.sql, routing_core_wrappers.sql and routing_topology.sql
>> >> that I did not run.
>> >> Does someone know what I am doing wrong ?
>> > A couple of thoughts here:
>> > 1. you have to run the topology command assign_vertex_id(), which I have
>> > never used as I wrote my own a long time ago.
>> > 2. You might (most likely) will need to load legacy.sql from postgis
>> > until I
>> > have had a chance to review, update and test all the sql code for
>> > compatibility with postgis 2.x
>> > Thank you for stepping on on the bleed edge and testing this. I look
>> > forward
>> > to here about your success and failures. Hopefully more success than
>> > failures :)
>> > -Steve
>> >> Thanks in advance
>> > _______________________________________________
>> > Pgrouting-users mailing list
>> > Pgrouting-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Frédéric Bonifas
>> +33672652807 skype:fredericbonifas
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
Frédéric Bonifas
More information about the Pgrouting-users mailing list
